Malachtgrun 320i cabrio from Australia
Tzantushka
Post Sun Nov 19, 2023 7:12 am
Well not much to report.
Happy to say I am driving the hell out of the car.
Road trips and weekends away this car is great.
Only major maintenance was getting the inner & outer CV boots changed. After 34+ years they were tired.
Thankfully I outsourced that to a workshop...
Post Sun Nov 19, 2023 12:53 pm
What a beautiful car .
And glad to hear you are driving the hell out of it too !!!
Tzantushka
Post Sat Dec 23, 2023 4:15 am
Thanks Mart - now it's summer and I'm officially on holidays - any excuse to take the E30.
Daily errands are much more fun, especially on a 25C // 77F deg sunny day
Tzantushka
Post Sat Jan 20, 2024 12:01 pm
Turning left into the hardware store driveway last weekend there was this almighty metallic THUNK noise.
Have had that noise before when the rear anti-roll bar (swaybar) came loose from the endlink / drop link on the LH side.
Sure enough, same problem.
Decided to put a stop to this once and for all.
- Jacked up the back of the car from the diff
- Removed the LH road wheel
- Pressed the swaybar link back on (with a clamp & socket + extension through the coil spring)
Then picked up a 12mm shaft ring to keep it on there (for our Australian readers = Bunnings)
Pressed that on with an 18mm socket & extension.
Perfect.
That should keep the sway bar link from popping off the the drop link / endlink.
Post Sat Jan 20, 2024 12:44 pm
Nice simple fix mate, well done !! :clap: :clap: :clap: :clap:
coopman
Post Sun Feb 04, 2024 3:35 am
I love Bunnings - I wouldn't go anywhere else for my shaft rings. It's sad that they cocked up so badly in the UK.
Tzantushka
Post Sun Oct 06, 2024 11:42 am
Pleased to say not a lot going on with the E30 over the Australian winter.
Was having some false failures pop up on the check control display (brake / tail / number plate) when everything was working OK with the right bulbs.
Replaced the bulb check module that detects the rear light circuits and everything seems fine now.
Also adjusted & lubricated the rear window while the trim panel was off.
Apart from that, lots of day trips, touring and errands...
Warning - photo dump ahead...
Tzantushka
Post Sun Oct 06, 2024 11:51 am
Post Mon Oct 07, 2024 5:15 pm
Hell thats looking great !!!
I wish our winters are that nice :(
Tzantushka
Post Fri Oct 11, 2024 5:12 am
Yeah - but I only take the car out on the good days.
You don't see the shyte ones
Tzantushka
Post Fri Oct 11, 2024 11:03 am
Also fixed the recurring cooling check control panel light.
Had nothing to do with the sensor or the panel.
The plug housing kept coming loose from the sensor - because of:
Crumbling rubber insulation around the connector buckets
Managed to fix that with a few wraps of insulation tape and then a sheath of 4:1 heat shrink tube.
Now the connector buckets are nice and snug in the plug housing and the plug stays put.
Post Fri Oct 11, 2024 1:06 pm
A very cool fix, glad you got it sorted mate.
Tzantushka
Post Sat Feb 22, 2025 9:14 am
Thanks Mart - simple fix are often the best?
Meanwhile, in other activities - gave the carpets an out-of-car deep clean.
Has been on the list of things to do for a while, but needed a good run of warm weather to properly dry the carpet as the foam is moulded to the carpet.
Pressure washer, scrub & wet vacuum, plus repaired some of the flaking rubber backing & foam.
Floorpan was in remarkably good shape - also gave the floorpan a coating of Penetrol for protection in case of moisture ingress...
Stuck with the Duplicolor Medium beige used for door cards & kick panel...
Light coats in a cross-hatch pattern & agitate the carpet nap to retain the fluffiness.
Turned out darker than expected.
But still a marked improvement from the faded carpet.
Also a good opportunity to install the DAB antenna for the Bremen head unit.
And also run a new FM / AM antenna cable, as the OEM cable had been cut & poorly spliced from a previous life.
Was able to buy a complete cable with the Hirtschmann connector - so the reception is now 10x better.
For our Australian viewers can buy them here from Sound Labs
Post Sat Feb 22, 2025 11:39 am
Lovely job and this will last for years as well !!
Tzantushka
Post Mon Mar 03, 2025 11:02 am
Yep, if it lasts another 30 years I am fine with that...
Oh, and also forgot to mention, after 3 and a bit years, was getting a few drips of oil on the floor.
Turns out the rocker cover gasket was tired - tighten-up of the nuts didn't solve it  - so it was cover off, clean-up & new gasket / plugs.
Everything was pretty clean & tidy after the head was done in mid-2021.
Cleaned the mating surfaces of the head & rocker cover.
Gave the rubber plugs a thin smear of Permatex ultra black RTV and tightened the rocker cover nuts as per the Bentley manual.
After a few short runs to do errands, everything looks pretty tidy.
​​​​​​​Will check gain in a few weeks.
Post Tue Mar 04, 2025 12:04 pm
Nice, but perhaps you should do something about that faded protection wax/lacquer on the intake manifold...
Tzantushka
Post Wed Mar 05, 2025 2:45 am
Ah yes, have often looked at that and thought I should do something about that.
But once you start, the rocker cover will need doing...
Then the strut towers (because it's there as well)...
And then the various brackets, bits & bobs in the engine bay...
I don't have the appetite to tackle those tasks - nor the $$$ for dry ice blasting, so I'm OK to leave it as original and call it 'patina'.
Post Wed Mar 05, 2025 10:32 pm
Sure. You could always try a fine (brass) wire brush, and/or thinners, applied sparingly so as not to splash other items...
Tzantushka
Post Wed Jun 11, 2025 1:39 pm
Minor update - while you guys are enjoying the nice weather, we have the rain down here.
Which means the windscreen wipers are getting a work-out on our cold winter days.
I was experiencing slow & juddering wipers when using the single sweep & intermittent functions.
When things warmed up and after several sweeps the med & fast settings were OK.
I followed this excellent write-up in the Wiki,
https://www.e30zone.net/e30wiki/index.p ... per_faults
Here are some pics for inspiration.
Linkage was good, but the passenger side spindle (RHD) had seen better days...
Part Number 61611353754 (Damper ring)
Motor & splash shields out for cleaning & inspection...
Yep, inners were gunked with solidified grease from the worm gear...
Some paper towels, electrical contact cleaner & gentle scrub with a toothbrush - all clean.
Replaced the worm drive grease (just used high temp bearing grease I had handy) and a thin smear of dielectric grease on the face of the contact rotor...
Connector was also cleaned-up with the vinegar + salt and water + baking soda solutions (here)...
(Dielectric grease on the pins to help minimise corrosion)
Ready for installation!
Few things I learnt along the way:
  • after disconnecting the linkage, loosened the 3 motor mounting bolts and THEN the bracket nuts - the bracket stayed in the cowl, triangular splash shield & wiper motor out through the blower access panel
  • dielectric grease for the female connector as well
  • I didn't follow the reassembly process & had the wiper arms swipe down toward the engine - make sure you install the linkage at the uppermost sweep position.
  • good chance to clean out the cowl & elephant trunk drain (vacuum debris and then soap suds with paintbrush & compressed air
