My alternator failed thursday so I bought and fitted a new one yesterday (had to remove AFM etc to get to it) everything was running fine but idle was a bit low so I messed around with the CO2 to try to get it to idle a bit stronger. Worked fine, for about an hour it drove perfectly. Then after that when I got to about 3-4K revs the car felt like it was hitting a brick wall and the power would die then come back on. Gradually got worse and worse, to the point that if I left it at idle it died by itself, or it was all over the place.
The MPG meter is also going crazy, all over the place.I cant even drive it because its impossible to do so. Had to tow it home last night:(
Any one got any ideas? Would it be to do with the AFM / CO2? Thats all I can think of right now, unless its something major major wrong (god hope not!)
