E30 Head Gasket - 1990 325i Convertible
Jam911
Hi Cotswold BMW
Can I have a price on a head gasket please?
Let me know if you need more info.
James
James
Jam911
I think I actually need the complete head gasket set BMW Part 11121730885
Jam911
Can you also add cylinder head bolt set to the quote BMW - 11121726478
Thank you
Thank you
Jam911
Can you please add
Exhaust heat shield - BMW part 51481945429
and a set of core plugs
James
James
Jam911
And water pump and timing belt please
Jam911
And timing belt tensioner pulley please
Cotswoldbmw
Hello
Please PM me your email address and I will send you a PDF with the prices on.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Jam911
Hi Jon
Great PM sent
Thank you
Great PM sent
Thank you
Cotswoldbmw
Hello
The part number you have for the head gasket set is incorrect, that it for a 325e not a 325i. The correct head set is no longer supplied but we may
be able to get all of the individual gaskets. Please can you make a detailed list of the gaskets you will require, valve stem seals etc and I can price them up for you.
Do you want the core plugs for the cyl head as well.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Cotswoldbmw
Are you having the cyl head skimmed?
Cotswold BMW Parts
01242 335365
01242 335365
Jam911
Hi Jon
Not sure if I want the core plugs will need to ask mechanic also same re cylinder head being skimmed.
James
James
Jam911
Let's say yes for the core plugs for the cyl head as well please
Cotswoldbmw
Ah OK, core plugs no problem, BMW no longer supply the thicker head gasket if you were to have it skimmed so we cannot supply.
I just need the list of all the individidual gaskets you want.
Jon
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Jam911
Ok thanks can you email me re everything else please...
Cotswoldbmw
I have sent the PDF
Cotswold BMW Parts
01242 335365
01242 335365
Jam911
Hi Jon
Received
Thanks for your help.
I need talk to my mechanic before ordering.
James
Received
James
Cotswoldbmw
No problem
Cotswold BMW Parts
01242 335365
01242 335365
