Tight steering
Corasdad
Post Sat Apr 27, 2024 3:47 pm
My car failed an mot the other day on a ball joint so I have replace the wishbones and drop links all went well and I took it for a test drive but now my steering feels responsive but tight and doesn't return to center on its own, is this normal I have I down something wrong
BenHar
Post Sat Apr 27, 2024 5:30 pm
Not normal, no.
Check that it all went back together correctly.
Ben
Corasdad
Post Sat Apr 27, 2024 6:04 pm
I have just looked again and think I tightened the ball joint nut to much, I have just backed it off and it's better :roll: rookie mistake
Post Sun Apr 28, 2024 12:57 pm
Dont forget to get the tracking done as well, it makes a difference to it when you change all those bits.
Post Sun Apr 28, 2024 3:18 pm
Impossible, the balljoints on the wishbones do not work like that and should be tight up to the subframe and wheel strut, definitely not loose!
Poor steering feedback is most likely due to the change in wheel alignment as said above
Post Sun Apr 28, 2024 4:39 pm
I did mine on an e30 years ago and I could barely drive it home from my friends house until it was tracked the next day.
There`s the fella for you mate !!
Corasdad
Post Sun Apr 28, 2024 5:30 pm
OK thanks guys
