E39 for conversion is it worth it
Corasdad
Post Thu Jan 18, 2024 5:58 pm
I have the chance to buy an e39 2.8 auto full car is it a good donor, would I still need the different sump and oil pick up also what else would be needed please
I am hoping to use engine and gearbox, so I would have all the looms needed and bigger radiator, I know the mounts will be different so I would need them.
The gear selector I would have and use from the doner.
flybynite
Post Thu Jan 18, 2024 8:15 pm
Yes the E39 will need the E34 sump and pickup as it is a rear sump just like the E36/46 otherwise it is as good a donor as anything else. What year is it? is it a M52 or M52TU (single or double Vanos)
Not sure about the gearbox if it will fit the E30 tunnel as I have not had much to do with automatics.
Apart from the wiring, take the ignition and ews modules in case you want to use them in the future.
Corasdad
Post Thu Jan 18, 2024 8:21 pm
1998 w reg
coopman
Post Fri Jan 19, 2024 4:44 am
I have an e39 2.8 auto (1996). My advice would be to buy the e39 and keep it as a daily driver.
flybynite
Post Fri Jan 19, 2024 10:03 am
Corasdad wrote: ↑
1998 w reg
Then it could be either M52 or M52TU you can tell by seeing if it has single or double vanos. Slight differences in what you need to do with them but basically the same..
For what you need, Have you watched the videos done by Spanner Rash on here? He walks you through quite well. :thumb:
coopman wrote: ↑
They are a good car no doubt but some here are just too far gone, like my E46. Salted roads in the winter take no prisoners and the cars around year 2000, once thy start to go they go quite quickly.
Lots of E39 M5, E46 M3 turned into money pits, M52 is a parts car at the moment unless in good condition then it is worth keeping on the road.
I still fancy an E39 but I need to get my E34 535i Sport back on the road first! 8O
Corasdad
Post Fri Jan 19, 2024 6:30 pm
coopman wrote: ↑
My e30 is my daily so don't need another but would like a more modern engine to keep up with traffic lol
Corasdad
Post Fri Jan 19, 2024 6:31 pm
flybynite wrote: ↑
Corasdad wrote: ↑
1998 w reg
coopman wrote: ↑
Thanks for the heads up will look into his vids
Corasdad
Post Mon Jan 22, 2024 10:15 pm
Deposit paid, one step forward 😊
Corasdad
Post Thu Jan 25, 2024 5:15 pm
Been watching spanner rash great vids, he fitted a brake booster from an e90, I have found one on Ebay but they state its off an automatic would this still be OK it looks the same as in his vids
Also my e39 has turned up😍😊
Post Thu Jan 25, 2024 6:42 pm
more pics please :banana: :banana:
Corasdad
Post Thu Jan 25, 2024 7:14 pm
She is rough but workable, sills are rusted out
Corasdad
Post Sat Jan 27, 2024 1:41 pm
Can I use the engine arms from the e39 or do I need e36
Post Sat Jan 27, 2024 8:07 pm
E36
Corasdad
Post Sun Jan 28, 2024 2:01 pm
OK thanks dan
coopman
Post Tue Jan 30, 2024 10:26 pm
Almost identical to mine - just more rusty.
Corasdad
Post Wed Jan 31, 2024 10:08 am
Lol in two minds if to fix it up or strip it for engine now lol
Corasdad
Post Fri Feb 02, 2024 9:04 pm
Anybody got E34 sump and pickup part number
Corasdad
Post Sat Feb 03, 2024 3:32 pm
I have seen some engine arms and rubber mounts that are 85mm so it lifts the engine 1" up has anybody used these to get extra clearance, is it worth keeping G the e39 radiator
Corasdad
Post Wed Feb 14, 2024 7:09 pm
Presuming I can get the engine and auto gearbox in will it mate upto the 1.8 auto diff, the the gearing be ok
Corasdad
Post Sat Feb 17, 2024 3:44 pm
flybynite wrote: ↑
Corasdad wrote: ↑
1998 w reg
How can I tell as I can't find the engine code, do I need oil pick up from an e34 or e38, I have read I need e38 if it's a tu engine
flybynite
Post Sat Feb 17, 2024 4:35 pm
Corasdad wrote: ↑
Looking at the photo I see dual Vanos and AFAIK the non-tu ended around 1998 along with the E36.
So for me it is a M52TUB28.
I have only dealt with the M54 so not 100% sure about the pickup.
Corasdad
Post Sat Feb 17, 2024 4:52 pm
OK thanks, I have just found a modified front subframe that means I can keep the rear oil pan, I have just emailed for confirmation that it does this so it may save me buying front sump.
He has just emailed back and it does stop you needing front sump so I think I go down this route.
flybynite
Post Sat Feb 17, 2024 5:24 pm
Corasdad wrote: ↑
Be careful what you use, there is a good subframe made for the S54 but that is quite expensive. There are a lot of bodge jobs out there that I would not touch with a barge pole. It is a significant part of the front subframe and not something to skimp on, especially with an uprated engine.
I saw one a while back made with butt-welded box section and bits welded onto the ARB. Fine round a drift track but I wouldn't trust them at road speeds.
Corasdad
Post Sat Feb 17, 2024 5:29 pm
Nearly £700 so not cheap
flybynite
Post Sat Feb 17, 2024 6:19 pm
Personally I'd do it the tried and tested way using OEM BMW parts. :thumb:
Corasdad
Post Sat Feb 17, 2024 7:30 pm
I know what ya saying but I am concerned about the E34 sump sitting low in my lowered car, I have already broke my sump which was cheap to fix but e34 sump are getting on for £500 and hard to find
flybynite
Post Sun Feb 18, 2024 10:31 am
Your money Your car etc etc but it is not something I would do. That welded anti-roll bar will be useless.
Lots of people run a front sump setup on lowered cars. My 323i and 325i were all lowered and front sump like all M20 cars and I never had a problem.
Personally I would raise the car a bit and fit a sump guard instead of messing the handling up but good luck with it which ever way you decide to go :thumb:
Corasdad
Post Sun Feb 18, 2024 1:40 pm
Thanks for your input I do agree with tried and tested methods and will probably do front sump after all I run a sump guard already but with a car full it catches on everything which can be annoying so might lift it up, it's only lowered 30mm so should be ok but as I say it catches all the time
Post Sun Feb 18, 2024 1:47 pm
I really cant believe people buy s**t like that, shouldnt pass an MOT..
Corasdad
Post Sun Feb 18, 2024 3:23 pm
One reason I looked at this is it's made by a racing team which I thought would test the subframe out putting it under loads of tension much more than my driving. But I will bow down to your knowledge as mine is less than limited
