The 316ti full send restoration
Si316
Post Thu Nov 23, 2023 6:18 pm
Hi All,
bit of a long timer on here with my 316.
Its been in multiple garages over the last 10 years slowly rusting and waiting for some much needed attention. I'm finally at a point in life where I can do my dream build so its full send from here on in!
I started this summer thinking I'd just get her running after rebuilding the DHLA 40 carbs and rewiring the engine. After finding some rust on the sils I decided instead to fully send it.
The car has been fully stripped down and is going to be dipped, metal worked, dipped again, e-coated, Then a full respray in Zinnobar red. I cannot wait to start rebuilding again. I've been gathering parts for a looong time.
Currently trying to figure out how to modify an m3 exhaust manifold to work with the m10 and RHD.
IG: Si316ti
2.0L M10, Twin carbs, big cam
Full send restoration in progress
Si316
Post Thu Nov 23, 2023 6:38 pm
Heres some recent updates of what ive been upto.
Carbs rebuild with bigger chokes and jets sized to suit and hopefully make some power and get up onto the 292 cam!
Engine rewired with all new wires and pins. Wiring includes megajolt EDIS-4 based ignition and wiring for additional VDO guages (quite proud of this)
IG: Si316ti
Si316
Post Thu Nov 23, 2023 6:56 pm
Alpina style ABS boot spoiler and mtech2 style side skirts
IG: Si316ti
Si316
Post Thu Nov 23, 2023 7:05 pm
The current head scratcher. Ports line up nicely and think getting the new flange on there will be the easy bit. getting around the steering column may be fun!
IG: Si316ti
Si316
Post Thu Nov 23, 2023 7:07 pm
And heres the reason I've decided its time to fully restore. The cills looked abit crusty so i did some investigation with a wire wheel.
IG: Si316ti
Si316
Post Wed Dec 20, 2023 5:13 pm
Well I got word that the E30 had come back from its date with an acid bath!
Went down to have a look and very plesently surprised at how solid the old girl is. The main bulk of the work seems to be sorting some issues on the firewall, Drivers side inner arch (shock tower side), the rear vallance, front core support and making good all the previous welding ive had done over the years!
IG: Si316ti
Post Thu Dec 21, 2023 7:55 pm
Excellent 8)
Any close ups of the shell?
Si316
Post Thu Dec 21, 2023 9:54 pm
Alright Dan!
I've got a couple. really surprised with how good it is. The main problems are fixing the dodgy repairs to the factory chassis mounts and a dodgy wheel arch welded on the passenger side.
The lower rear vallance is toast and the battery tray has seen better days but the scuttle is solid.
IG: Si316ti
Flaffy1991
Post Fri Dec 22, 2023 12:15 pm
Doesn’t look too bad that! Seen a few nightmares come back from acid dip in the past (mostly old jap stuff though I might add)
I love a full strip back project! Looking forward to more updates on this one.
flybynite
Post Fri Dec 22, 2023 12:29 pm
Looks good, where did you get it done?
One thing I have been told it make sure it is really well pressure washed off after as the dipping stuff has a habit of creeping out of joints after painting.
One place I am thinking of using for paint won't touch it if I have it dipped. I was tempted to get it e-coated then leave it for a while and get on with other stuff and let it sit before painting
Si316
Post Fri Dec 22, 2023 12:34 pm
The restorers use Enviro strip for the dipping and e-coat. I've heard some horror stories too but ive heard about horrors with blasting too.
The restorer is really confident in the acid dipping process and hes the one whos putting his name to it and painting it so im happy if hes happy.
IG: Si316ti
flybynite
Post Fri Dec 22, 2023 2:08 pm
Yeah there is no ideal answer, blasting can warp panels. I have looked at envirostrip and SPL, going to pay both a visit in the new year before I commit.
Si316
Post Thu Jan 11, 2024 12:00 pm
Had word that the car is now in bodywork primer and ready for metal work. Were going to be ordering repair pannels and putting together the action plan for metal work.
IG: Si316ti
Si316
Post Fri Jan 12, 2024 10:50 am
Afew more pics fro mthe restorer of it going into bodywork primer.
IG: Si316ti
BMGM3
Post Sat Jan 13, 2024 4:53 pm
Did you not go for the e-coat ?
Si316
Post Sat Jan 13, 2024 4:54 pm
It’s having all the metal work done then going back for another dip and e-coat then final paint.
IG: Si316ti
twenty
Post Sat Jan 13, 2024 7:04 pm
Looks amazing!
Who is doing this work and roughly how much is this costing if you don't mind me asking?
Si316
Post Wed Feb 28, 2024 8:43 pm
The restorers are called Focus Five Autoworks in Cheshire and doing an absolutelly fab job!
Some progress on the front and rear chassis rails:
IG: Si316ti
rix313
Post Wed Apr 03, 2024 7:29 pm
Great work so far dude 8)
Post Thu Apr 04, 2024 1:15 pm
What lurks between seams gives me nightmares! :lol:
Si316
Post Thu Apr 04, 2024 1:49 pm
Haha, me too! so glad hes having a good look at everything on it. Looked pretty clean but still hiding some horrors. Makes you wonder watching some of the patch work restorations what there not seeing/sorting!
Managed to get hold of some dream bits. So happy to have some Gaz gold coilovers and WMS brakes!
IG: Si316ti
