So…… a bit of an update here.
Got myself a oil pressure sensor and replaced that to stop the leak, still can’t find the wiring for it. Seems like it might of been cut off so I’m looking into the diagrams to work out where I can link that back to.
Also did an oil and filter while I was at it, however when I drained the oil it seemed a bit milky. Checked the coolant while I was there and there was hardly a drop in the tank.
Had a spare day today so thought I’d have a proper look at the oil issue and possibly the idle at the same time.
Car has been idling erratically since I got it. I’ve checked all the normal stuff, air leaks, ICV, dizzy, sparks blah blah blah. Absolutely no issues anywhere.
The only way I’ve ever been able to explain the idle to anyone is it sounds like it’s got a rowdy cam in it….. remember this part for later.
I noticed it was quite tappy as well, and the previous owner said he had the head “refurbished” so thought maybe the valve clearances were wrong causing the bad idle and the tapping too.
So today rocker box off and valve clearances done along with a proper inspection for any wear or any obvious issues.
Unfortunately after doing all that I checked the coolant and there was nothing but thick milk in the header tank… looks like the heads coming off for a gasket.
0.25/.010
Now I don’t know for absolute sure. But is that a schrick cam….? I didn’t notice until I was looking back through these photos. But looking online the schrick cams have the yellow marks on and the engraving too? This would explain the erratic idle too as having a look online M20’s with schrick cams sound exactly the same as mine does….
Somebody tell me I’ve finally got a win with this car?!
Anyway. While I was messing about I thought I’d have a look at the reg plates lights as they’ve not worked since owning the car either.
Found the wiring diagram for it
Started following the wiring, Fuse seems to of been replaced. Bulb holders seem to of been replaced too. Then I came across ANOTHER beauty of wiring repair.
Rather than try fix the issue, the previous owner had just added his own wiring coming from the positive for the sidelight bulb. Across spaghetti junction and into the reg plate lights. You can see the piss poor attempt at soldering that has failed coming from the light cluster.
However the positive spades are pinched between the body and the massive oversize wood screws they’ve used to hold the bulb holder in place.
Anyways, ripped all that extra wiring out and started fresh. No 12v to the positive for the reg light, followed the wiring back and saw the rear light check relay was the only thing left.
Found it in the boot. Two screws later, checked the continuity across the coils. No continuity. Pulled it apart and was greeted with this.
Anyone have any idea if I can get a new one from anywhere as it seems only used ones available online.
If not I will build something myself.
