Its been a while...long period of happy motoring, but now I've got a strange one.
The ICV - original BMW one, died, caused cut outs and then a failure to start, I reckon it was pulling the ECU down and caused some kinda short. Disconnecting it allowed me to get home.
I bought a 50 quid non BMW pattern item and although it runs ok the idle is 1k rpm so she gets hot when idling for longer periods.
There's no air leaks so its an ICV issue, the ecu is 380 and I'm wondering if the death of the original has torched the control electronics.
Maybe the cheap replacement is crap and I need to buy an OEM ICV but its a load of cash to end up in the same position.
All wiring and volts appear fine but the new ICV seems to get real hot, hotter than it should.
Bit of a pisser as the mot is coming up and I'm concerned about the gas tests as the idle is a bit mad.
Any thoughts at all?
Paul
