Brake pipe size
Phid
Post Sat Apr 08, 2023 3:38 pm
I need to replace a couple of brake pipes at the rear. I was going to by a kit - but what size pipe and fittings do I need please?
flybynite
Post Sat Apr 08, 2023 5:38 pm
4.75mm pipe and M10 fittings. If you don't get them as a ready made kit then make sure you do the correct flare and do the job right and get cupro/nickel (Kunifer) not copper :thumb:
Phid
Post Sun Apr 09, 2023 7:48 am
Thank you
Post Sun Apr 09, 2023 8:51 am
In real money its 3/16 inch tube, as advised definitely buy cupro/nickel tube
Phid
Post Sun Apr 09, 2023 7:01 pm
Yes thanks - I’ve bought the cupro nickel pipe.
reggid
Post Tue Jul 04, 2023 12:18 pm
Also fittings are bubble type
E30 325is with M20B31
