E30 s50 b32 build cost
RossDavies
Mon Apr 03, 2023 9:09 pm
S50 b32 conversion cost list.
Engine complete with ancilliaries £4450.
Rear half of e36 328i prop (not used) £145.50
E36 z3 2.8 5 speed box and prop £500.
Prop shaft overhaul and modification £480
Renault clio servo £39.99
Brake rod extension and plate £32
Brake and clutch fluid £14
E28 oil pickup, sump and dipstick £432.80.
Engine oil £56
Sump gasket £13
Bmw engine mount rubbers £100
Welder £160.00
Flywheel bolt sealer £8
Welding mask £39.99
Bmw intake elbow and no6 intake pipe £160
E90 servo and mc (not used) £19.95.
E34 oil pump £37.50
Pas fluid £7.99
E34 steering uj's £35.00
E36 m3 Radiator £90
Fan switch £15
Valve cover gasket £24
Jubilee clips £15
Satin engine paint £34.94
Silver paint £15
Acl race main bearings £135.
Oil filter £5
Spark plugs £88
Acl assembly lube £12.50
Rear main seal housing gasket £7.00
Rear main seal £8.47
2x knock sensors £67.29
Constant pressure seal £5.50
Vanos seals £218
Wiring harness adapter £119
Wiring harness covers firewall £149.58
Lhd steel water pipe £207.70
Heat shield sleeve £19
Cable ties £10
Throttle position sensor £38.88
Carb cleaner £5
Underseal 10
Pre paint degreaser £7
Delphin paint £12
Primer £10
Sandpaper £4
Filler £8
Clear lacquer £12
Spacers to push out accumulator £9.38
Vacuum hose and blanking bung £7.52
Vacuum blank £5.99
Stainless jubilee clips £13.90
Coolant temp sensor for e30 dash £9.90
Hoses and reducers for oil separator to sump pipe £26.12
Nice bolts for drive belt pulleys £12.69
Bmw green multi function relay £19.89
Cost of selling and having to rebuy headers. £175.
Revcounter coding plug £26.90
E46 oil cooler and pipes (not used) £97.75
Anearobic sealer £13.99
Ramps to have rear of car elevated £44.99
Oil pressure t piece not used too long £12.81
Oil pressure t piece £21
Purple tag steering rack £269.99
Steering shaft link £75.00
Steering rack mount spacers £7.95
C101 plug (not used) £13.00
Subframe reinforcement plates £32.30
Oil pressure and temp gauges £94.22
Revcounter overlay £149.07
Center vent gauge pods £24.00
Twin core wire £7.95
Header tank and mounting plate £149.99
Top rad mount £20.
Oil temp sensor adapter £6.17
Stainless flux cored wire £132.22
Stainless exhaust collectors (not used) £69.99
Relay and plug for fan £5.14
Loom tape £5.99
Loom conduit £13.95
5 and 6 mm silicone hose £15.39
Two core cable £18.97
Two core cable £7.97
Rubber grommets (not used) £3.29
Flat bar for headers template £8.60
Rubber grommets £3.68
Perspex to fit oil cooler £6.65
Spacers for bottom rad mounts £10.09
High temp plastic paint black £14.70
Header upper adjustment tubes £120.
Tubes for headers after collectors £173.88
Welding costs for headers £320.
5 bar inline fuel pump £105.85
Extra exhaust mount and rubber £17.30
Rad fan £42.95
Fan mounting kit £7.95
Manifold nuts £8.45
6x exhaust manifold gaskets £46.32
Heatshield embossed plate £16.26
Rear silencer heat shield £50.49
E36 m3 throttle cable £66.99
New rear silencer mount rubbers £15.08
Fuel filter £11.30
Cone air filter kit £87.00
Rad hoses £37.59
Electrical connectors £9.95
Stick air filter box £168.95 (not used)
Diff oil £47.90
Hoses and reducers for heaters, header tank and vacuum £112.32
Blanking bungs for after cat o2 sensors on supersprint £8.85.
New coolant cap £13.50
B & Q bolts and washers various £80
Flat bar and brackets various £40
Coolant £17.50
Battery £90
Battery terminal for power distribution £12.00
Full supersprint exhaust system £2200
Total eye watering cost £13,276.18
fixedwheelnut
Mon Apr 03, 2023 11:09 pm
Wow :clap: :clap: Lovely build!
Tue Apr 04, 2023 5:12 pm
X2 :banana: :banana: :banana: :banana:
It may look a lot on face value but just look at what you have !!!!!!!!!!!!
A car where build quality is second to non ( hand built ? ) and you know every single nut and bolt .
What on earth would you hope to get for even double that amount ??
Big credit mate :clap: :clap: :clap: :clap:
RossDavies
Wed Apr 05, 2023 7:26 am
Thabks guys it means alot. The car runs very very well and pulls increadibly straight and planted. The re con purple tag rack feels really tight, it feels like a brand new car. I just gotta get it dynoed and check for faults, and im gunna time a 0-60. If i knew it would have cost that much though i woukd have run a mile, so im glad i went in unknowing really.
Wed Apr 05, 2023 8:38 am
Thats a bargain price in the grand scheme of things, well worth the money and effort 8)
RossDavies
Wed Apr 05, 2023 9:04 am
Its amazing i love it. Thanks for the steering shaft dan.
RossDavies
Thu Apr 06, 2023 1:28 pm
Cleaned it up yesterday. Looks stock as can be.
Robby249
Mon May 08, 2023 10:02 pm
Looks really tidy buddy, I have just built the same but haven't added it all up lol
RossDavies
Thu May 11, 2023 9:52 am
Thanks. The air filter i think is no good, so is coming off for a bigger one today, before dyno on monday.
reggid
Mon Jun 26, 2023 6:56 pm
Damn that’s expensive considering it’s just the parts
E30 325is with M20B31
Cloggy Saint
Tue Jun 27, 2023 10:05 am
£26.5K would buy quite a lot I would think. Looks great though.
HartgeH27
Tue Jun 27, 2023 9:30 pm
I like that......................................a lot ! Great work there.
rix313
Thu Jul 13, 2023 9:22 am
The most eye watering bit was spending £80 at B&Q on fixings :mad:
HartgeH27
Thu Jul 13, 2023 9:28 am
:banana: That made me laugh to start the day !
Thu Jul 13, 2023 4:56 pm
You must be well out of touch with current car prices!
