rear seat base replacement.
steve_k
Post Sun Mar 12, 2023 5:21 pm
afternoon i'm looking for a bit of help & advise.
has anyone got any hints or tips on getting the rear seat base in a 2 door back in place "clipped" down?
i removed mine the other day as the gasket on the fuel pump inspection panel needed to be changed,
got all that done but now i can get the seat base to lock in place.
i can push the seat base back as far as it will go then when i push down i get one side clipped in but not the other side,
but if i pull the clipped in side back up the other side will clip in.
basically i can only get one side in place & not the other,
so, anyone got any hints or tips?
BenHar
Post Sun Mar 12, 2023 6:14 pm
Make sure there's nothing stopping it from going right back.
If all clear push it harder!
Ben
HartgeH27
Post Sun Mar 12, 2023 6:42 pm
Speak to Chris Goose, he, I am sure will advise
steve_k
Post Mon Mar 13, 2023 7:33 am
thanks guys i'll have another look later today if i get chance, fingers crossed.
flybynite
Post Mon Mar 13, 2023 7:52 am
Bent it pulling it up? Happens if you pull one side too hard
As above make sure it is fully back, seat belts are usually the culprit.
Left any tools under it? :D
steve_k
Post Mon Mar 13, 2023 9:02 am
when i pulled it up i had an each end to make sure it was lifted equal,
there's no tools under it & the seat belts are up out the way.
i've got a feeling that horrible looking matting underneath is rucking up at the back & stopping it going back fully.
