s50 carbon fibre plenum
buster
Post Fri Feb 17, 2006 6:17 pm
Hi all,
After pissing about with the standard alloy plenum i decided to cut a small chunk out of it to make it fit around the smaller servo im using.
A couple of weeks ago i came across a carbon fibre plenum.I have seen pics of them before and one or two in e30's but i wasnt sure it would fit.
The pics i have seen looked as though they'd clear the servo even though the whole airbox is bigger than standard.
Anyway,i bought one,and now its on.
It has radius'd belmouths inside the ports and equal length pipes,i did have to shorten them though to make it fit.
Here's a couple of pics :
It was getting dark so sorry about the bad pics.
I dont know how much power it will give,to be honest as long as its the same or more than standard im not bothered.The main reason for fitting it was that it clears the servo and master cylinder.
I will take some more in the light tomorrow.
Let me know what you think ,
cheers
andy
Jamesb318is
Post Fri Feb 17, 2006 7:46 pm
That looks immense mate!
and if s14's with carbon airbox's and e46 csl's are anything to go by, it should sound awesome too!
jmc330i
Post Fri Feb 17, 2006 7:56 pm
Fair play :cool:
I looked at buying one, but didnt want to risk buying it if it didnt fit.
How much clearance is there for the servo and MC? Which servo did you use (I forgot)?
It looks great, looking forward to seeing some clearer pics :thumb:
James
'91 325i Sport
'93 318i touring 16v
Andy335Touring
Post Fri Feb 17, 2006 8:04 pm
Looks cool :cool:
I bet it will sound ace as well !
buster
Post Fri Feb 17, 2006 8:16 pm
cheers guys,i will take some better pis tomorrow when im working on it.
Need to re-bend the dipstick tube,i just hope it doesnt snap as i had to bend it out over to clear the old plenum,i'll have to bend it back over into the block to come up inbetween inlet 1 and 2.
Might try some heat on it.
buster
Post Fri Feb 17, 2006 8:18 pm
jmc330i wrote:Fair play :cool:
I used the golf servo and audi master cylinder (25mm).
It just clears !
glenn
Engine Transplant Services
Post Fri Feb 17, 2006 8:30 pm
WOW!!!!!!!!!!!!!!!!!!
andy, that looks so
8) 8) 8) 8) 8)
well done mate
jmc330i
Post Fri Feb 17, 2006 8:33 pm
It just clears !
Nice. It does look just brilliant.
Will it need any mods to fit the MAF and an air filter or is there enough room up front?
James
'91 325i Sport
buster
Post Fri Feb 17, 2006 8:40 pm
cheers glenn 8)
James,
Theres room for the MAF but i think its gonna be tight for the filter !
I may have to cut a hole and drop the filter down into where the nearside brake duct is,either that or a really thin filter.
Anyone know about this alpha N ??
Apparently i can use it to get rid of the maf,dont know much about it appart from its a piggy back ecu.
buster
Post Fri Feb 17, 2006 8:43 pm
this is the master cylinder and servo i used :
Audi 25mm master,golf servo.
jmc330i
Post Fri Feb 17, 2006 8:50 pm
I did talk to Ant briefly about going standalone on my S50 and I also had a look round the MS site.
It seems it may be possible to just use MS to run the fueling (and possibly the sparks) and leave the normal ECU to run the Vanos. That way the MAF could be removed.
James
'91 325i Sport
tim_s
Post Fri Feb 17, 2006 8:51 pm
very nice! this one looks much better than the last carbon plenum i saw on an s50 - it had nasty angled flanges where the trumpets met the throttle bodies...
how much have you cut the trumpets back? what does it sound like now?
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
buster
Post Fri Feb 17, 2006 9:05 pm
I took about an inch out,dunno what it sounds like,wouldn't hear it as its got no exhaust at the mo !
DieselMeister
Post Fri Feb 17, 2006 10:46 pm
Tidy.
I'd like a carbon plenum just for noise (once drove a CSL - sounds like an unsilenced V12 when it hits 5krpm 8) ) but if it improves the fit of an S50, all the better.
Nice work buster :thumb:
adamS
Post Sat Feb 18, 2006 11:31 am
:wan:
Its just too much. When this is finished i'm coming down to steal it!
Good effort dude :cool:
cpc
Post Tue Feb 21, 2006 4:24 pm
Cool - where did you get the plenum from ? I could do with one for development .
Phil
buster
Post Wed Feb 22, 2006 8:18 pm
i bought it off ebay :mad:
adil325i
Post Thu Mar 02, 2006 10:20 pm
hey guys,
i dont know if this may interest you lot, but i received this email from jon at treehouse racing regarding the exhaust manifolds on our s50 conversions -
Adil,
Thanks for the email. Yes, for E30 engine conversion cars, my control arm bushings (Eyeball Arms) allow clearance for Stock US exhaust and/or Euro headers to be fitted without modification. They have the same offset as the E30 M3 and 1995 M3 which of course is desireable.
If you would like a set, Paypal $218USD to jon@treehouseracing.com and I will send a set out to you right away. I ship to England, Germany, France quite often so it's no big deal.
Thanks,
Jon
I dont know if anyone has much experience with these bushes. how could these work?
All the best,
adil
ps - this isnt an advertisement of any kind - it could make the s50 to e30 engine conversion a helluva lot easier though!
jmc330i
Post Fri Mar 03, 2006 2:43 pm
adil325i wrote:it could make the s50 to e30 engine conversion a helluva lot easier though!
Dont forget those are for LHD cars.
The manifold will still need a lot of modding to fit around the steering joint on our RHD cars.
James
'91 325i Sport
gcorky
Boost Junkie
Post Fri Mar 03, 2006 7:03 pm
very nice buster your car is great m8 :D
525 sport
adil325i
Post Sun Mar 05, 2006 1:46 am
thought jons prospects were a bit ambitious - if these worked, im guessing there would have been a group buy on these arms. oh well, i guess ill look forward to the sweat and anguish involved in getting all the piping sorted... sniff...
i posted something of this kind in regards to the carbon fibre airbox allowing the standard servo and cylinder to be fitted - i guess this answers that post! im thinking of getting a remote servo - Ԛ£130 on ebay, and thats brand new. lets see how it goes.
Frenchguy
Post Wed Mar 08, 2006 9:34 pm
adil325i wrote:im thinking of getting a remote servo - Ԛ£130 on ebay, and thats brand new. lets see how it goes.
Remote servos are for single-circuit braking systems, unless you fit two of them. And I'm not sure they cope well with DOT 5.1 brake fluid, which you'd want to use with such power.
Just my opinion !
bottlecapE30
Post Thu Mar 09, 2006 1:27 am
looks great how does it sound
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
buster
Post Fri Mar 10, 2006 12:09 pm
buster wrote:I took about an inch out,dunno what it sounds like,wouldn't hear it as its got no exhaust at the mo !
