Heater help
Corasdad
Post Fri Nov 04, 2022 12:47 pm
My heater fans only worrk on no4 so I went out today and got new resistor and plug it it it worked on no2 for few mins then went off ai waited for bit and it cam back on then off and hasn't come back on any ideas what else to look at. Ould it be the fan it's self
Post Fri Nov 04, 2022 1:45 pm
Yes it probably will need cleaning and oiling up,have a look in the "Wiki", I think there is something in there about it.
Corasdad
Post Fri Nov 04, 2022 1:56 pm
BenHar
Post Fri Nov 04, 2022 7:34 pm
Corasdad
Post Sat Nov 05, 2022 3:25 pm
Before it take it all apart would you guys just buy new rather than try fix
flybynite
Post Sat Nov 05, 2022 6:05 pm
If it is a genuine one may be worth trying to clean it and see but if it has already been replaced with a cheap one, (why it might have failed in the first place) no point in trying to fix, just get another.
Be aware there are different ones for cars with AC that do not fit the ones without.
BenHar
Post Sat Nov 05, 2022 6:51 pm
If it still turns then a bit of lubrication will get it nearly as good as new.
Ben
Corasdad
Post Sat Nov 05, 2022 6:58 pm
Thanks guys
Post Sat Nov 05, 2022 7:01 pm
Thanks guys
Could you take a few pics of how you do it please ?
This could help all of us. :D :D :D :D
Corasdad
Post Sat Nov 05, 2022 8:20 pm
Yeah weather dependant I will look sunday
Corasdad
Post Sun Nov 06, 2022 12:17 pm
OK didn't manage to take pics but it's possibley fixed,
I removed the cover in the engine bay, then removed the plastic fan cover, then trust wd40 and run the fan for ten mins and all seems ok
fixedwheelnut
Post Sun Nov 06, 2022 2:35 pm
Three in one oil works better and lasts longer :)
Corasdad
Post Sat Nov 19, 2022 12:42 pm
OK my blower stopped again so I bought a new one but my heater is still intermittent any other ideas
Corasdad
Post Sat Nov 19, 2022 1:02 pm
OK it clunks when I switch it on full power Nd the fuel gauge moves a bit
flybynite
Post Sun Nov 20, 2022 10:44 am
Sounds like a wiring or earthing problem. Did you bench-test the old motor and the new motor together before fitting?
