RUBBER FUEL HOSE
f11rfn
Post Wed Aug 24, 2022 1:20 pm
Hi guys need some advice .. my rubber fuel hose in the engine bay is leaking .. I’m going to replace both of them .. original bmw hose can only find in 10cm length these hoses need to be longer to go from engine bay to under chassis .. I have found same dimension hose 8mm internal and 13mm diamater total at gsf would this be ok to use ?
https://www.gsfcarparts.com/186bm0010?f ... LLx44ePm8Q
Contours
Post Wed Aug 24, 2022 9:45 pm
It would, Bmw would not have made the original hose in any event.
Mitchen
Post Thu Sep 01, 2022 3:41 pm
BMW supply this by the meter. Thus ordering two will get you one long 2 meter hose. Part number 16 12 1 180 409
1990 320i Coupe SE
viewtopic.php?t=253048
steve_k
Post Sun Sep 04, 2022 9:56 am
or just go to a local motor factors & buy it from there, there's no difference in it at all.
Post Sun Sep 04, 2022 1:28 pm
There is a difference Steve, the quality of this stuff varies more now than it ever has, thanks to china....
"Standard fuel hose" says to me that it is not suitable for fuel injection systems
Dont skimp on parts that could result in injury/death/total loss
steve_k
Post Sun Sep 04, 2022 4:19 pm
i know what you mean, though the pace i use i've never had a problem, he's always been cheaper than the dealers.
mind you i do have full braided steel fuel lines on mine so.......
