Blue Temp sender Q.
tonyppe
Post Thu Feb 16, 2006 1:26 pm
if i were to do this on the weekend, what would it entail?
is the sender in the water system? would i need to drain, and bleed the water (the bms are w*nkers to bleed for air locks :( )
should i be expecting hands full of cuts afterwards cos its so awkward to get to?
how long would it take?
help please! :)
Cloggy Saint
Post Thu Feb 16, 2006 1:36 pm
This thread should answer most of your questions
http://www.e30zone.co.uk/modules.php?na ... ic&t=28525
FlappySocks
Post Thu Feb 16, 2006 2:31 pm
It's very easy providing you have a spanner that will fit! I didn't and had to buy myself a new set of offset ring spanners.
http://www.ccw-tools.co.uk/catalogue/pr ... cat_id=255
Removing the brown sensor helps (you may want to change that too while your at it!).
You will get a bit of coolant leakage, but no need to drain it - just top it up afterwards.
Stuart.
tonyppe
Post Fri Feb 17, 2006 1:42 pm
so whats the part numbers anyone know?
id like to go n get one tomorro from cooper a217 but everytime i get something from there, they r out of stock. or the toffys give me funny looks cos they sell BMs. :x
Dan318-is
Post Fri Feb 17, 2006 1:51 pm
FlappySocks wrote:It's very easy providing you have a spanner that will fit! I didn't and had to buy myself a new set of offset ring spanners.
Stuart.
The OEM spark plug tool fits the sensor perfectly
Gwynleym10
Post Fri Feb 17, 2006 2:05 pm
I assume its for a m20 engined car, cause m40's are slightly different, but still not hard
London 2 Cape Town
www.Overlandinthesun.com
tonyppe
Post Fri Feb 17, 2006 8:19 pm
yea sorry M20
