Hi - I’ve got a pre-facelift 4 door (D-reg) E30. While doing something else, I’ve found that there’s water in the RHD rear seat base. No water in the footwell, backrest or in the boot.
I was installing coilovers on the weekend and there didn’t appear to be any holes in the wheel arch or floor. I’ve taken the carpets off and nothing obvious there either.
The car has a sunroof but there’s no evidence of water inside the sunroof or in the headlining.
Any ideas would be appreciated.
Water in the rear seat (4 door car)
Cloggy Saint
I had this issue on my 2 door when I parked nose up on slope of my drive. Pulling the seat out it looked to be coming from here as shown in the image.
This was from the trim round the top/back of the window, I've not fixed it properly yet by replacing the seals/grommits, but putting tape over the gap stopped it happening
- Attachments
So i park facing slightly uphill, but where should i check on a 4 door car?FRMATT wrote: ↑Mon Mar 21, 2022 9:31 amI had this issue on my 2 door when I parked nose up on slope of my drive. Pulling the seat out it looked to be coming from here as shown in the image.
I didn't describe it well, it's the trim around the C pillar has a gasket and some grommits, 2dr I know but 4dr I think would be attached in same way:Wingzero wrote: ↑Tue Mar 22, 2022 3:31 pmSo i park facing slightly uphill, but where should i check on a 4 door car?FRMATT wrote: ↑Mon Mar 21, 2022 9:31 amI had this issue on my 2 door when I parked nose up on slope of my drive. Pulling the seat out it looked to be coming from here as shown in the image.
https://www.realoem.com/bmw/enUS/showpa ... Id=51_0830
See attached image for what I did to mine to prove it was this, need to get round to ordering the bits to fix properly
- Attachments
