Testing Auto TPS & Pin Numbers
PG325
Post Sat May 07, 2022 6:56 pm
Hi,
I want to check my TPS is working as expected.
It's an auto TPS and has 6 pins, I know which number pins to test, but I don't actually know what is pin 1 etc out of the 6.
Is there a digram of an auto TPS with pin numbers shown anywhere?
PG.
TriggerFish
Post Mon May 09, 2022 2:14 pm
Is it not on the connector itself? Most connectors have little numbers on them to avoid this. You can see an example here: https://i.ebayimg.com/images/g/grcAAOSw ... -l1600.jpg
Alternatively, if you can find the TPS in a wiring diagram, they usually have pin numbers and wire colours, so combine the two and you should get an answer :)
https://forums.bimmertips.com/viewtopic.php?t=7
flybynite
Post Mon May 09, 2022 4:11 pm
PG325 wrote: ↑
Hi,
PG.
On the 6-pin TPS plug the numbers are next to the base of the pins at the bottom of the socket. Difficult to photograph but easy to see with a torch. :thumb:
