My 320i..
Mitchen
Post Sun Apr 17, 2022 9:28 pm
rix313 wrote:
Sat Apr 09, 2022 5:36 pm
Great to see you still have the car. Really enjoyed catching up and realising how much was still available in 2016 from BMW.
Thanks mate. It’s shocking how much is NLA now. Even serviceable items like a rocker cover gasket are now discontinued. Makes you wonder how hard it’ll be in another 10 years.
1990 320i Coupe SE
viewtopic.php?t=253048
Mitchen
Post Sun Apr 17, 2022 9:46 pm
Okay so a lots gone on this last week, culminating in a solid bank holiday weekend of E30 graft.
Started off with a full inspection 2, with brake fluid and coolant. Whilst servicing the sports auto fluid, also saw fit to replace the rusty old sump. Pretty pointless addition but looks shiney
I also needed to replace the sunroof headlining. A common issue on these is that they end of disintegrating over time. The glue wears off and the foam falls apart, giving you a head full of debris everytime you open the sunroof. I struck gold by finding a mint example on eBay for £50.
Photo below is of the original busted up panel. You can get these re trimmed, but expensive and seldom match the original.
1990 320i Coupe SE
Mitchen
Post Sun Apr 17, 2022 9:53 pm
So after that.. I was preparing for the installation of a new front valance.
Mine had seen better days and I took the opportunity to get the brake ducts and lower lip painted at the same time.
So it’s not a massive job, but mine was hindered by a lot of missing nuts bolts and speed clips, from historic body shops messing with it.
I went from this…
To this…
Can’t beat fresh new panels…
1990 320i Coupe SE
Mitchen
Post Sun Apr 17, 2022 10:00 pm
Anyway back to today… I took the time on Saturday morning to wash and clay bar the car in preparation for a day of detailing today. I don’t have a garage so I was working against the sun. Washing the car again again at 10am this morning and then waiting until 2pm for the sun to go around my house, so I could start compounding.
I have a Flex forced rotation polisher and I use the Koch Chemie system of compounds and pads. I finish off with Car Pro Reflect and then some carnuba for protection. Doing 4 passes of the whole car between 2-7pm has annihilated me.. and tomorrow I will be doing nothing but resting these aching bones 😣
However the results were unbelievable. Not a swirl or scratch in sight.
1990 320i Coupe SE
Tzantushka
Post Mon Apr 18, 2022 6:26 am
Looks fantastic!
And yes also have noted a few parts becoming NLA more recently
rix313
Post Sat Apr 23, 2022 12:19 pm
I've always been pretty impressed with what is still available. Problem is they peak and troff with what they decide to make and the prices fluctate like a bastard as well. 1 year ago you could get genuine front wings for £240 ish, now they are £460 and one side is essentially on an eternal lead time.
Mitchen
Post Fri Oct 14, 2022 3:49 pm
Ok so whilst the car is in winter hibernation I've decided to do some major surgery.
Although this car is pretty solid, any E30 owner that tells you their car is rust free is either a liar, delusional, or it's undergone a major/bareshell resto :)
The car has had 2 major repairs in the past and they've both been done badly. Firstly two rear inner arches back in 08 before I acquired the car and secondly a new rear panel in 2015/16 under my stewardship. Unfortunately I wasn't in the trade at the time and went with a bodyshop that I should have avoided. The old adage 'you get what you pay for' was made for car bodyshops.
Although I supplied a genuine rear panel the whole job was a bit of a lash up.. areas that should have been protected and treated at the same time weren't and sure enough fast forward 6-7 years and rust is starting to appear at the joins of the rear panel and rear quarter. It's also been letting water into the rear boot pockets. This is a prime of example of having a body shop that aren't familiar with the car or at least cars of a similar ilk... or maybe they were just s**t :mad:
Whilst the car was in storage the last 2-3 years I've been planning on getting this work done and just decided this winter is the prime time. Although my current bodyshop will destroy your bank account, their experience, craftsmanship and attention to detail is second to none.. especially when it comes to E30's.
Below gives you a jist of what was occuring through water going through seams that should have been sealed and then sitting with nowhere to go. Corrosion starts and then spreads.
Time to cut off the rear panel :o:
The OS boot pocket was beyond saving and had to go...
Any one who's gone down this route will no doubt appreciate how scarce repair panels are nowadays.. particularly genuine parts. I managed to get a section of the boot pocket from Holland.. but the rest needs to be fabricated.
1990 320i Coupe SE
Mitchen
Post Fri Oct 14, 2022 3:55 pm
Here's the repair panel in all it's glory
Then came the craftmanship.. This is just the OS.. same still be done on the passenger side and then the new rear panel to be attached.
1990 320i Coupe SE
Post Fri Oct 14, 2022 4:21 pm
:clap: :clap: :clap: :clap:
Skill has to be learned , earned , only with time ,there can not be another way.
Unfortunately a lot of cash as well.
Well not really, you get what you pay for yes ????
It`s only expensive when it`s done more than once.
Very cool work, lovely to see "proper" skill. :banana: :banana: :banana: :banana:
Mitchen
Post Fri Oct 14, 2022 4:59 pm
Absolutely. You'll be hard pressed to find a run of the mill bodyshop on an industrial estate that can do that level of work and remain true to the factory look. Most could carry out the task.. but firstly the crevices and gaps wouldn't look the same and secondly you'll be back in a few years time when it starts rusting again... just like me :D
1990 320i Coupe SE
Mitchen
Post Mon Oct 17, 2022 5:03 pm
So the time for attaching a rear panel to this old jalopy has arrived
And we have lift off.... :clap:
1990 320i Coupe SE
Post Mon Oct 17, 2022 8:46 pm
Nice to see you getting your issues sorted :D
This is 99% wrong as only 1% of bodyshops know how to do a proper job, and unfortunately less than 1% will actually do a proper job!
Mitchen
Post Fri Oct 21, 2022 2:59 pm
So things are progressing nicely with this. Welding and bag sealing is now done..
1990 320i Coupe SE
Mitchen
Post Fri Oct 21, 2022 3:04 pm
We're now ready for paint.. which will be happening on Monday.
1990 320i Coupe SE
Mitchen
Post Fri Nov 11, 2022 2:53 pm
For those who care about such things here are some images of the finished article. Now stored away until Spring.
1990 320i Coupe SE
brutus
Post Sat Nov 12, 2022 2:23 am
,, MMM,,
good panels, mate,
she looks more than than shes worth
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
Mitchen
Post Mon Nov 14, 2022 8:08 am
,, MMM,,
good panels, mate,
Thanks pal
1990 320i Coupe SE
rix313
Post Mon Nov 14, 2022 4:21 pm
Beautiful work on the repairs.
fixedwheelnut
Post Thu Dec 29, 2022 11:33 pm
Excellent work, love it.
