Idle rising and falling
Further info. The rhythmic rise and fall of revs only happens once the engine reaches temperature. If I disconnect the MAF it has no effect. If I disconnect the O2 sensor the engine idles smoothly. Is it as simple as this sensor is buggered?
Also, the M50 loom has an Evap sensor terminal. On the assumption that the car and original fuse box does not have air con I have just left this terminal. Could this be contributing? Do I need to plug something into it?
