I now have a new problem with my 1985 B reg 318i with a M50B25 non vanos conversion, whilst driving I changed down a gear and as soon as I put the clutch in the engine cut out and wouldn't restart. In short I have no spark and the fuel pump isn't pumping.
After getting it back home I pulled a couple of spark plugs out and with them connected to the wiring, turned the engine over on the key but could not see a spark from either of them.
I've checked what I thought was the fuel pump in the tank, which turned out to be just a fuel level sender unit - pre facelift E30, then checked the actual pump under the car, no noise or buzzing to indicate it was running when cranking the engine on the key. Disconnected the wiring to the pump and put 12V leads to it and it pissed out fuel immediately, so pump is working at least.
Next I checked the crank sensor resistance between pins 1 & 2 and got a reading of 494 Ohms. Checked the cam sensor and got 975 Ohms...which I think means both are within acceptable limits?
I was really hoping one of these sensors would be out as now i'm stuck for what to try next...any ideas???
Also on disconnecting both cam and crank sensors I didn't realise they both use exactly the same plug and now I can't be sure I've put them back in the right slot
