Advice on 2.9 M20 Build
LucianoDfrench
Post Thu Mar 03, 2022 6:50 pm
Hi guys
Any advice on a 2.9 built vir Sr20ve 86mm piston... Connecting rods size and any other mods that should be done?
Can i use e36 328i crank (84mm) with 135mm rods with the sr20ve piston?...
Standard Sr20ve setup:
136.3mm conmecting rods
86mm stroke crank
86mm Piston
flybynite
Post Fri Mar 04, 2022 9:09 am
Hi guys
86mm stroke crank
86mm Piston
Never heard of using that Nissan piston, I suppose anything can be made to work but it is a lot of trial and error for something that can be guaranteed not to work as well as one of the tried and tested methods.
Why not get the correct Mahle Motorsport piston and make a 2.9 known to work?
Post Fri Mar 04, 2022 2:40 pm
Its also a 4 valve per cylinder engine so the piston crown is completely the wrong shape
LucianoDfrench
Post Sat Mar 05, 2022 9:28 am
The Sr20Ve have a flat top actually almost similar to the one from an e36 325i/328i motor with a slight dish making its compression 11.1
LucianoDfrench
Post Sat Mar 05, 2022 9:32 am
Hi guys
86mm stroke crank
86mm Piston
Makes sense... A friend told me it will work and made about 240hp N/A on the wheels with that setup with 276/284 cam... Maybe ill try the C20XE piston, that's a pretty common 2.9 build but compression sits at 10.0 with that piston... Hoped i could go about 11.0 +
Post Sat Mar 05, 2022 12:58 pm
A dished piston that gives 11:1 compression, that cannot be in an M20 build surely!
reggid
Post Sun Mar 20, 2022 5:49 am
There is a lot more to a piston than the bore and CR
E30 325is with M20B31
