big list of bits
Looking for genuine BMW parts at discounted prices? Try here!
Stewart0028
Post Thu Feb 17, 2022 6:46 pm
After the following bits for my car
Would it be possible for price breakdown on each item as I expect some to be too expensive for what they are and may be able to reuse some of the old ones if they are too expensive
quite a large list
33311136428 x2 subframe studs
33331132546 x4 subframe stud washer
33311133463 x2 subframe nuts
33326760361 x2 subframe bolts
33176760337 x1 diff front bolt
33171136186 x2 diff rear bolt
33321090693 x2 upper arm inner bolt
33326760668 x2 upper arm inner nut
33171090824 x2 lower arm inner bolt
33326760364 x2 lower arm inner nut
33321139132 x4 upper and lower outer bolt
33326760668 x4 upper and lower outer nut
33326760389 x2 trailing arm bolt
33326760668 x2 trailing arm nut
07119900587 x2 front knuckle upper bolt
07119905753 x2 front knuckle upper nut
31311136465 x4 front knuckle lower bolt
51311977607 x1 front windscreen trim
51311977608 x1 rear windscreen trim
51318119281 x1 rear windscreen trim
51368119961 x1 left popout upper seal
51368119962 x1 right popout upper seal
51368119963 x1 left popout lower seal
51368119964 x1 right popout lower seal
51712234044 x1 set twist side skirt seal
51711977678 x1 scuttle trim
Cotswoldbmw
Post Fri Feb 18, 2022 10:04 am
Hello
No problem, please PM me your email address so I can send the breakdown.
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
Stewart0028
Post Fri Feb 18, 2022 10:07 am
Cotswoldbmw
Post Fri Feb 18, 2022 12:25 pm
Hello Stewart
I have sent the breakdown on a seperate email to you.
The 186 bolts are not available anymore.
Jon
Cotswold BMW Parts
01242 335365
