325i engine misfire
peterjk
I need some help!! My 325i starts ok. Soon as it comes off the choke injector power falls off and it misfies and backfires really badly , eventually coming to a halt. I think it maybe the fuel regulator relay. Any idea's very welcome.
Assuming you're saying the engine performs OK until it begins to get hot, then the most likely problem is a dud engine water temp. sensor, telling the ECU it's still cold and over fueling. Cheap and easy to change.
peterjk
Thanks matey. I'll check this out. The engine is in fine fettle. Low mileage car, cambelt changed regularly ect
SVBMW
I keep seeing ref to this sensor and replaced mine last year, but I'm starting to get the same / similar problem again.
The question is do they go as quickly as a year apart??
I'd some idea before I go out and get a new one
Tris
peterjk
Problem Solved!! Fitted new engine temperature sensor as suggested by Brian. NO problem since then. Thanks and well done!!
