318is service parts
Binkerment
Post Mon Jan 10, 2022 7:15 pm
Long shot but I don't suppose there's a list of service parts and oils availible anywhere for a 318is?
I recently changed the drive belts but I'd like to complete a full service before it goes back on the road in April.
ah
Post Mon Jan 10, 2022 7:40 pm
When you say service are you talking inspection or oil service, have a look here on the servicing part of the page.
https://www.e30zone.net/e30wiki/index.php/318iS
Post Tue Jan 11, 2022 2:38 pm
Step in Rich, one for you mate :clap: :clap:
Binkerment
Post Tue Jan 11, 2022 9:06 pm
I am meaning an inspection service. All oils, filters plugs etc.
Green
Post Thu Jan 13, 2022 12:14 am
Most of the information is on that link, I think the air and fuel filter is the same in all petrol E30s.
The basic m42 servicing guide in the wiki is unfortunately missing but I imagine that would have had everything you’d need.
Binkerment
Post Fri Jan 14, 2022 8:05 pm
Cheers mate. I'll go through the list and order what I need. One more question. I'm not 100% sure what diff is in the car. I know normal gear oil can't be used in an LSD but can the oil for the LSD be used in a non LSD car? I don't see why not to be fair
And how would I know of it had a LSD or not?
BenHar
Post Sat Jan 15, 2022 6:56 pm
Under one of the bolts holding the back cover of the diff there should be a tag bolted on that shows the ratio. If it also has an S on it then it is an LSD.
Ben
flybynite
Post Sun Jan 16, 2022 9:58 am
Get yourself something like a Haynes manual. I used one to service, strip down and rebuild mine before there was internet. For heavy rebuilds they are not as good as they used to be but for servicing they are fine.
Jack the whole back end up and turn one wheel, if the opposite one turns the same way you have a working LSD,
If it goes the opposite way you don't. That can also happen if your LSD is worn out in which case academic what diff oil you put in it.
It can also mean you have a motorsport 1.5 way LSD which has no preload but they were only medium case and I doubt you have one of them in a 318is.
Binkerment
Post Tue Jan 18, 2022 9:48 pm
I didn't think the Haynes manuals covered the M42 16v engines.
rix313
Post Tue Jan 18, 2022 10:51 pm
They dont sadly. So you need to get an E36 manual to cover the M42. That said fundimentally all the oil grades and levels etc are the same as the M40. I've always used a good quality 10w40 engine oil, gear oil is ATF same as the power steering fluid, open diff 75w90 or LS oil if it is an LSD but unlikely it is. It's an engine at the end of the day, they all need the same TLC. Consider taking the injectors out and send them to Injectortune for an ultrasonic clean, test and rebuild. Excellent value for money.
flybynite
Post Wed Jan 19, 2022 8:24 am
Yes sometimes you have to mix-and-match to get the correct manual, same for some other BMWs but all the info is there.
Haynes say they do a manual for the 134bhp 1.8 E30 but I'm sure the red one says it does not cover DOHC
Binkerment
Post Mon Jan 24, 2022 6:55 pm
I never thought of that. So the E36 manual should cover the engine and the E30 manual will cover the rest of the car including electrics etc?
I'll try and source both.
Lastly, are parts like the HT leads dealer only parts?
onthames
Post Tue Jan 25, 2022 9:39 am
Some things are best bought from dealer but most of the time the parts are made by a manufactured and then the BMW logo is stamped on.
From my list it looks like Karlyn STI are the manufacturer. Can often get a LOT cheaper that way.
https://www.ebay.co.uk/itm/152594240876 ... Swol5YyS1x
From BMW:
Manufacturer list:
Boge: Shocks, bushings, top mount.
Sachs: Shocks, clutch, fan clutch, bushings, top mount.
Febi Bilstein: Shocks.
Lemforder: Control arms, bushings, drop links, tie rods, top mount.
Bremi: Distributor cap & rotor.
Karlyn STI: Ignition leads.
Bosch: Lots of electrical stuff, from spark plugs to headlights, ECU, ignition coil, switches, sensors, relais etc.
Hella: Headlights, switches, sensors, relais, taillighthousings, headlight carriers, other electrical- plastic and metal parts.
Jurid-Textar-Ate: Braking parts like discs, pads, booster, master & slave cil.
Lucas Girling-Ate: Brake calipers/rear cylinders.
TRW: Repair kit calipers
Eberspaecher-Boysson: Exhaust.
SKF: Wheelbearings & other bearings.
ZF: Gearbox, steeringrack & pump.
Vickers: Steeringpump.
Behr: Radiator & thermostat. Fan clutch.
Goetze: Headgasket set, other gaskets, pistonrings.
Mahle: Pistons.
Contitech: Auxilairy belts, timing belt.
Mann-Mahle: Filters.
Wahler: Thermostat.
Getrag: Gearbox.
Motometer: Instrument cluster & gauges.
VDO: Instrument cluster & gauges, engine sensors.
Hirschman: Antenna.
Blaupunkt: Radiounits
Nokia Speakers
Brose Electric motors power windows
Ebasto Electric motor roof
Metzeler: Aerodynamic accessories (M-tech) like spoilers, skirts etc.
Pfeba: Aerodynamic accessories
Gerhardi:Facelift Edition side skirts
Stabilus:Shock bonnet
Ribe: Headbolts
Ullringer: Alarmsystems
