e30 headlights
SarelErwee
Hey, Im looking to find some cheap but best for the price headlights, preferably plug, and play and something a lot brighter than my stock sealed beams. I've done a considerable amount of research and I can't really find anything under $300, just wondering if anyone in here would know where to point me. Thanks!
steve_k
hi, there's always the likes of depo headlights, either smoked or standard, & use the likes of osram nighbreaker bulbs.
clear ones. https://www.ebay.co.uk/itm/223731823343 ... SwlQ5e1-t5
smoked ones. https://www.ebay.co.uk/itm/333374720826 ... BMps3bws1f
hope that helps.
hope that helps.
kdevitt
Depos will let moisture in and wreck your head!
steve_k
mine never have, mind you i did reseal the lense before fitting,
My Depos are fine after two years and are much brighter than stock.
paultv
+1 for the Depo's ...much brighter...look good and cheap...as Mart says fit with 160% Osrams and you get best possible brightnes and beam pattern without resorting to HID which ain't legal on an E30...don't waste money on anything LED.
Paul
Paul
kdevitt
One side is fine, an otter has moved into the other side theres so much water in there. I'm sure that resealing them would alleviate the issue.
YODI
I'd love a set of the clear ones but both sellers have really bad feedback.
Does anyone know the Depo part number for the clears?
