Fuel pump location, '87 325i Cabbie manual RHD
ricardo2019
Post Tue Jan 11, 2022 4:07 pm
Hi Guys, hope everyone is well.
Have a slight petrol leak on my car just in front of the rear N/S wheel, where I think ive located the fuel pump? Am I correct as most of the web seem to say its under the rear seat.?
TIA guys.
onthames
Post Tue Jan 11, 2022 4:27 pm
Yep under rear seat. Should be some videos on YouTube about removal
stones
Post Tue Jan 11, 2022 4:48 pm
That would be the fuel filter under the car as said the fuel pump is in the fuel tank under the rear seat.
flybynite
Post Tue Jan 11, 2022 5:44 pm
Early Jetronic cars had a pump there as well as under the back seat but by '87 and motronic times it was removed and only the filter is there.
ricardo2019
Post Tue Jan 11, 2022 6:31 pm
ImageThis is it. Why does the fuel filter have wires to it?
ricardo2019
Post Tue Jan 11, 2022 6:36 pm
Its a Feb '87, model.
flybynite
Post Wed Jan 12, 2022 8:03 am
Because it is a pump :D Not known later cars to have them but early Motronic cars were a bit of a basket case and they are all well over 30 years old so anything could have happened
ricardo2019
Post Wed Jan 12, 2022 8:51 am
Thanks mate. So would you think that is the only pump?
flybynite
Post Wed Jan 12, 2022 4:26 pm
No there will be a pump under the back seat too, at least that's the way it is on the L-Jetronic models like my 323i.
My 325i is a bit later and only has one pump which is under the seat.
ricardo2019
Post Sun Jan 16, 2022 1:21 pm
Thanks guys.
biffer
Post Sun Jan 16, 2022 2:54 pm
My '87 car has just the one pump in front of the n/s wheel- under the seat there is just the fuel-gauge sender-unit.
The way to tell if there is a pump in-tank is to check the number of electrical wires going into the top of the tank- if just 2(i think) wires are present then that suggests just a sender-unit is inside the tank. More wires means a sender plus pump is fitted.
