318 I S misfire ?
blade7
Post Sat Feb 26, 2005 12:49 am
Hi my search for a 318is has turned up quite a nice one at a dealers not too far away but its a bit pricey,one thing I did notice though was that just above idle speed the car has a slight hesitation before reving up freely, could this be something expensive to fix or relatively simple ?, I was told the car has been "chipped" and its also had a large cone filter fitted, I realise its not easy to diagnose a fault without seeing the car but any informed opinion would be appreciated, thanks.
MrBroon
Post Sat Feb 26, 2005 1:36 am
Is the engine bay sparkly clean? If so suspect water ingress after some over ethusiastic jet/pressure/steam washing. I'm suffering from the same problem at the moment, it's gonna be a strip it down and dry it job plus some liberal application of a WD40. Hope this helps, if you get any more info on your proposed cars probs pls let me know.
Geeman
Post Sat Feb 26, 2005 7:48 am
Could just be a small hole in an air pipe... which is VERY common and very difficult to see/find on initial inspection.
Could just be water ingress as MrBroon said.
Might even be slightly over fueling due to the chip. Do you have the original to replace to see if it changes anything? Do you know what make the chip is?
Giles.
blade7
Post Sat Feb 26, 2005 8:41 am
Hi again and thanks for the replies, dont have any info about the mods at the moment but there's loads of paperwork with the car so I suppose it would be recorded somewhere, as I said from the initial inspection the car looks good but at Ԛ£1800 for cash it seems a bit expensive what do people here think ?.
Karan
Post Sat Feb 26, 2005 11:44 am
thats a good price if the car is 'mint' with perfect bodywork/paint and correct bbs wheels, lip spoiler and good engine without epic mileage
Karan
Dom
Post Sat Feb 26, 2005 12:22 pm
price is a tad steep unless it's mint as karan said.
my iS has this problem but not too vicious and not all the time. I think extra air is being drawn in through damaged breather hoses so they're next on the list to be replaced.
blade7
Post Sat Feb 26, 2005 3:39 pm
The car has the right wheels with the caps present, its done around 138k but had a freshen up 10k ago with rings and shells etc, still undecided about it though, the reg no is H884 HAD anyone recognise it ?.
peterjk
Post Sat Feb 26, 2005 3:45 pm
This may be a vaccuum pipe problem. The air gets sucked into the inlet manifold via a vaccuum pipe. Usually oo of the brake servo. This will cause a weak mixture hence hesitation when you put your foot down.
Demlotcrew
Post Sat Feb 26, 2005 3:48 pm
its had bottom end work? hmm thats a bit weird it must have not been looked after well, i have two 318is cars with more than that on the clocks and they have had no engine work. (one has had chain done)
Andrew
blade7
Post Sat Feb 26, 2005 3:56 pm
Supposedly the car had low oil pressure hence the rebuild, there are receipts for thousands but I think there's been around 7 owners, not all little old ladies I suspect.
Demlotcrew
Post Sat Feb 26, 2005 4:28 pm
as long as its in good nic now thats all that matters.
Where abouts in Cambs are you? i could come and see it with you.
PM me
Andrew
