Piston markings…
Acaciastrain360
Post Wed Dec 29, 2021 12:16 am
Me again… does this ‘0’ marking mean that it’s a standard sized piston?
Thank
Youuuuuu
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
flybynite
Post Wed Dec 29, 2021 9:54 am
Acaciastrain360 wrote: ↑
Can't say I'm 100% sure about the "0" none of the pistons I have here have it but the 83.98 is a standard 84mm piston size :thumb:
There are also markings inside that can tell you a lot like the make etc
Looks to me like a 2.5 low compression piston but can't tell further without seeing the side and underneath the skirt walls
Acaciastrain360
Post Wed Dec 29, 2021 11:56 am
flybynite wrote: ↑
Thanks for you reply, it is a 1989 325i SE and was automatic
Is there any relevant difference between a low compression and a standard engine?
I’m currently rebuilding the engine and needed to know for the piston ring set… but I will take more pictures for you and see if it’s low comp as I may need a different head gasket? Or not?
Anyway thank you
flybynite
Post Wed Dec 29, 2021 2:11 pm
Anyway thank you
No real 'standard engine' aside from the Cat engines there were two : M20B25 early high comp 9.7:1 and later low (technically medium) comp 9.4:1
Have a read here
https://www.e30zone.net/e30wiki/index.php?title=M20
For a facelift SE those pistons look correct as 9.4:1 pistons. If it was a chromie 325 then it would probably be a 9.7:1.
AFAIK all the changes were in the piston crown and skirt, everything else (rings gaskets etc) should be the same. More will depend on if the head or block has been skimmed.
I'm sure if you search there are comparison photos like here
https://www.r3vlimited.com/board/forum/ ... 25-pistons
HTH :D
Acaciastrain360
Post Wed Dec 29, 2021 3:52 pm
Awesome thanks man! Yeah it’s fully serviced etc and neither head or block has been skimmed, nor do they need it… it’s a lovely little engine. I’m just rebuilding as it done 170k and been standing for about 11 years!
Thanks again I really appreciate the help
