Getrag 260 whining first gear
Acaciastrain360
Post Fri Nov 12, 2021 3:28 pm
Hey guys, I’ve acquired a getrag 260 and the chap said it used to whine in first pulling away….
Is this a straight forward job to replace the 1st gear bearing? I’m a competent DIY hobbyist, or is this a professional affair?
Any help will be greatly appreciated! Thanks
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
rix313
Post Fri Nov 12, 2021 6:12 pm
I've just had a full gearbox inspection done and had new seals and vapour blasting and it was £414 all in. I thought it was pretty cheap and it looks brand fire new. I consider myself competant in this field however I did chose the path of least resistance and just get a gearbox specialist to worry about it.
flybynite
Post Fri Nov 12, 2021 6:51 pm
I have rebuilt a couple of 260s couple of decades ago for rear bearing which is what I have found usually goes. Rebuilt a 245 couple of times as well. 260s lasted well after rebuild (100k) 245 did not but that is no surprise really
It is doable but the gearbox has to come apart completely for most things, you need to be clean and organised, follow a good manual like an early Haynes. Problem is seeing what is causing the noise may or may not be obvious.
Next one that needs doing I will take it to a specialist.
Acaciastrain360
Post Fri Nov 12, 2021 9:26 pm
Thanks for your help dudes….
Acaciastrain360
Post Fri Nov 12, 2021 9:27 pm
What specialist did you use? That seems good value to me too!
rix313
Post Mon Nov 15, 2021 7:26 pm
Been trying to reply to this for days but something kept going wrong :LOL:
This is the before and after:
The Gearbox Centre Northampton. They do a lot of classic stuff and have one guy there who specialises in them. Dan I believe it was.
BristolE30
Post Tue Nov 16, 2021 9:23 am
Wow looks great!
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
reggid
Post Sun Dec 05, 2021 10:20 am
Unfortunately you aren’t going to get much done with the internal gubbins on a job of only a few hundred. So you’d want the box to not need much
Definitely a job for the specialist
E30 325is with M20B31
