Not wishing to hi-jack another thread, there has been talk of "Boron" steel.
What is your understanding of this in relation to sheet steel for car manufacture??
I have machined "Tool Steels" for die`s etc and if it had a content of the said Boron, then it was so hard we could barely touch it but the tool/die would last a life time.
What percentage of Boron is used and why do they use it on car bodies?
Cheers Mart.
Different Materials
- Tzantushka
Good to see your curiosity hasn’t diminished in time!
Basically the car manufacturers like these Ultra High Strength Steels (UHSS) because of : High strength, low weight and workability in typical sheet steel gauges for hot and cold pressings.
When Ford owned Volvo & other brands under their Premier Automotive Group division, Ford learnt a great deal from those manufacturers who where using UHSS for improved crashworthyness and light weight in complex sections of chassIs. Think B pillar, front rails, A pillar hinges.
Here’s a good article that helps introduce why.
https://www.ford.com.au/technology/boron-steel/
https://automotive.arcelormittal.com/ne ... oXC40-COTY
With the different grades and % used be prepared to go down the rabbit hole of detailed metallurgy...
