Blower Resistor
Elkcarc
Post Tue Nov 02, 2021 5:34 pm
I'm having a bit of a moment with a blower Resistor. On one of my car's it's a really simple, right in the middle resistor, no problem. But on my 1987 325 its to the side, is it just a case of giving it a good yank? Also does anyone know the part number, as I've only been able to find the common in the middle resistor. Cheers
tha881
Post Tue Nov 02, 2021 6:53 pm
Access is from inside the car, it's a bit tricky to get to, is your car right or left hand drive?
Contours
Post Wed Nov 03, 2021 3:13 pm
You tap it through into the passenger compartment after you unhook the 4 pin plug from inside the car--I think that is the type of resistor you have .
Elkcarc
Post Fri Nov 05, 2021 10:03 pm
It's right hand drive. I shall give it a good go this weekend unhooking it from the inside. Cheers
MunsterScot
Post Sun Nov 28, 2021 11:20 am
I replaced my one back in May 2019. Cheapest place I found then was https://www.leebmann24.de/. Part number 64111375754. This is for the brown blower resistor.
twenty
Post Mon Nov 29, 2021 9:20 am
leebmann24 is fantastic but doesn't deliver to the UK after we left the EU.
