M40 Timing Belt : Old and New ?!
elvirbgd
Post Fri Oct 22, 2021 6:38 pm
Hello E30 fans!
Last days I noticed that original timing belt which was built-in E30 M40 engine had width 19 mm. But when you check in EPC timing belt for BMW E36 M40 model, width was 20,7 mm. That "newer" timing belt you can fit on E30 M40 model also. My question is : Is it possible that BMW made some kind of modification of timing belt during the E36 era ? Because of problem with often break of timing belt on M40 engines.
Cheers!
Post Sat Oct 23, 2021 6:52 pm
elvirbgd wrote: ↑
Hello E30 fans!
Cheers!
Welcome to the zone mate and you MUST talk to the guy`s at Cotswold on here and the timing belt will only break if the car has not been looked after winkeye
rix313
Post Sat Oct 23, 2021 8:10 pm
ECP isn't the greatest so I wouldn't read too much into their measurements. I can't see how making it 1.7mm wider would really change much in terms of longevity.
