My 325i
onthames
Post Tue Oct 05, 2021 12:28 am
Just going to post progress on the car here. Done a lot already but some left to go.
Since I'm pretty new to car restoration I'd appreciate feedback and advice on my processes. I'm bound to make many mistakes so if you see anything in this thread that makes you cringe then don't hesitate to point it out! I won't be offended
onthames
Post Tue Oct 05, 2021 12:35 am
Yesterday replaced the torn SE boot lid liner in a darker leather effect vinyl and sprayed the tool tray in black after priming with grey primer
I'm currently doing a few small surface rust repairs and one area of penetrating rust on one of the jacking points. I'm removing the rust, going back to bare metal in the area and feathering the underseal around. Them priming with epoxy primer, using seam sealant where necessary and then using dinitrol underseal - going slightly over the surrounding underseal to create a good patch. Between doing that I'm working on replacing the suspension to a bilstein b12 kit, replacing all rubber bushings, rebuilding the shifter (new bushes etc), repainting the subframes, struts, replacing the discs, rebuilding the differential, replacing the main gearbox seals and replacing the oil sump gasket. Oh and removing the engine so I can tidy up the engine bay! Lots to he getting on with.
onthames
Post Tue Oct 05, 2021 12:38 am
A bit of progress on the diff. Starting to get back to bare metal although it was caked in rust so taking a while. Wire wheel not working particularly well to remove the paint so tomorrow I'm going to use starchem paint stripper on it (serious stuff). I thought about blasting it to remove the paint but the risk of getting sand inside is too high.
onthames
Post Tue Oct 05, 2021 12:40 am
The subframe was very stuck but this trick I read on some forum post saved the day.
tha881
Post Tue Oct 05, 2021 10:47 am
Nice work, the SE boot liner and tool kit looks fantastic
Tzantushka
Post Tue Oct 05, 2021 10:55 am
I like this!
Subscribed!
ah
Post Tue Oct 05, 2021 5:39 pm
Out of interest how did you get away with this, my wife would of had a sh1t fit if that was my diff in our house.
onthames
Post Tue Oct 05, 2021 7:08 pm
Luckily my parents are quite easy going and as long as stuff isn't in the house permantly then they're okay with it. I just had it infront of the radiator for a few hours to dry after I had been degreasing it in the parts washer.
New compressor arrived today. Got it hooked up to the sandblaster and works a treat! Now time to start sandblasting all the parts and prep for painting.
aimlessrock
Post Tue Oct 05, 2021 7:59 pm
best means to de-rust the diff is hydolosis, - check it out on youtube.
ive done a couple over the years.
E30 320i Convertible (1989)
190 Mercedes (1988)
Post Wed Oct 06, 2021 4:57 pm
The OEM police wont go for this but it`s your car and you can do what the hell you like to it !!!!
For what it`s worth , I think they look "Shit Hot" !!! :clap: :clap: :clap: :clap:
onthames
Post Wed Oct 06, 2021 9:12 pm
Started prepping some parts today for painting
For the control arms I'm etching, spraying por 15 and then spraying por 15 top coat. After etching the control arms I washed off the solution using water and dried with a heat gun however some small amounts of surface rust formed. This isn't an issue though.
onthames
Post Wed Oct 06, 2021 10:41 pm
I got this off of Amazon for £70. Should make a good spray painting area. Set up the garden as I'll start spraying later this week. Planning to do most of it in one go and then bring the "booth" down again until I need to spray again.
onthames
Post Thu Oct 07, 2021 4:52 pm
Definitely gonna spray in bigger batches from now on. Paint went on well but was a proper faff. For a first try tho not bad.
Post Thu Oct 07, 2021 5:21 pm
Great idea and if and when it gets very messy .....who cares ??????
Wish to hell you lived near to me lol.
onthames
Post Fri Oct 08, 2021 11:11 am
I started rear subframe disassembly yesterday and had some real difficulty with the bearings. The inner races came out leaving the outer which meant I couldn't get any purchase with a pressing tool due to the lip on the trailing arm itself. In the end I welded a ring on the outer race which contracted the bearing allowing me to hammer it out.
onthames
Post Fri Oct 08, 2021 8:53 pm
Had great difficulty removing the rear wheel bearings today. Had to get the grinder out and left a small 0.5mm deep cut on the hub. Does anyone know if this will pose a problem?
Post Sat Oct 09, 2021 1:41 pm
Does the inner track fit over this, as in you have to press it on over the shaft and if so should not be an issue.
onthames
Post Sun Oct 17, 2021 8:16 pm
Dash out and AC and cruise control going in soon... Just need to tidy the wiring and redo lots of seals. Switch over to new dryer, new pressure switches and a new parallel flow condenser and electric fan.
fixedwheelnut
Post Sun Oct 17, 2021 8:36 pm
Top tip for the future, clamp the flange in a vice, use a pry bar, bang it in with a hammer to start a small gap, then with a second person using a second pry bar both lever the inner race off together, sometimes you need a thick spanner to pad it out to get the last bit of movement.
Also getting the bush to drop out of the recess in the bodywork, we did them one at a time, use the long end of a pry bar up inside the aluminium part of the bush and give it a good wiggle until it drops out under the weight of the subframe, use an axle stand to catch it from dropping too far :)
https://www.screwfix.com/p/roughneck-ro ... lsrc=aw.ds
aimlessrock
Post Sun Oct 17, 2021 9:54 pm
with the dash out chek the steel work on the bulkhead- esp round the battery box and round the drivers side.
190 Mercedes (1988)
Tzantushka
Post Mon Oct 18, 2021 3:03 am
Sweet!
Some Tesa cloth tape will come in handy for the wiring looms.
https://www.tesa.com/en-au/industry/tesa-51608.html
Probably over kill, but I ended up chiselling out the 2x lower fracture bolts for the steering column (and replacing with regular bolts) so I could drop the steering column with ease
Avoids damaging the steering column shroud on the dash re-install.
Plus allows me to replace parts on the steering column without removing the dash.
onthames
Post Tue Oct 19, 2021 9:28 pm
Under the sound insulation?
onthames
Post Tue Oct 19, 2021 10:16 pm
My dad tried my homemade "spray booth" today and helped me paint some parts. Also picked up these very rare sill strips with the mtechnic design.
onthames
Post Fri Oct 22, 2021 5:51 pm
Bit the bullet today and started removing rusty bits near the front jacking point.
Cloggy Saint
Post Fri Oct 22, 2021 5:56 pm
Getting well stuck in! Aren't the sill strips still available from the dealer?
onthames
Post Fri Oct 22, 2021 6:15 pm
The sill itself that I've cut out was actually intact, but there is 3 bits of metal that make up the sill at the bottom edge itself, two of which come down from the floor pan area and the piece in the middle had rusted out completely. The large bit of the outer skin of the sill I've cut out I plan to put back in once I remove the two other skin layers from it - I removed it so I can weld the repair to the inner part in from both sides.
Instead of having three bits of sheet metal making up the bottom edge, I plan to just use two as it makes the repair much easier. I'll compensate by using slightly thicker sheet
It seems most of this was caused by a blocked drainage hole for the sunroof which was filled with underseal when I removed it... I'm lucky the damage isn't worse to be honest.
onthames
Post Fri Oct 22, 2021 6:32 pm
This is my idea for the repair:
Green = 1.8mm thick patch
Red = 1.8mm thick patch
Blue = existing metal I've cut out and plan to put back in
Purple = butt welds
Yellow = plug welds (Between red and blue part)
Never done this before so any feedback would be appreciated :)
Cloggy Saint
Post Fri Oct 22, 2021 6:47 pm
I meant the M-tech sill strips!
onthames
Post Fri Oct 22, 2021 6:53 pm
Ah, yes they are, but are unbelievably expensive.
aimlessrock
Post Fri Oct 22, 2021 9:35 pm
check all the pannels behind the dash - i found some holes right at the back past the battery box - with the dash out you have full access- if needed remove the wings (bolt on) and do a full check.
190 Mercedes (1988)
onthames
Post Wed Oct 27, 2021 8:18 pm
So... It's been one hell of a time. I fucked up the patches and decided to start again a few times... This resulted in me having more of a gaping hole than I started with! Lesson learnt. Got something I'm somewhat happy with now.
Will clean up the area thoroughly. Epoxy prime the area, seam seal the welds and the underside will get a coat of undercoating too.
Post Sat Dec 11, 2021 2:31 pm
Any more reports to share with us ??
onthames
Post Mon Dec 13, 2021 4:08 pm
Finished welding and now working on all the suspension components etc
Post Mon Dec 13, 2021 5:18 pm
Lovely to see things coming together and nice work mate :clap: :clap: :clap: :clap:
BenHar
Post Mon Dec 13, 2021 9:18 pm
Good to see some progress.
The two welding pictures seem to show some missed bits. Will you be going back to fix them?
Ben
