E10 FUEL ISSUES?
NigelA
Tue Sep 28, 2021 12:55 pm
I am reading press comments about the problems which can be caused by E10 including possible (or likely) condensation in the fuel tank. My 325iT is now used most often about once a week and for short journeys so the the fuel in the tank is normally kept quite low. The fuel lines are original. The question is is this scenario setting up for future problems please? One option might be to continue searching for E5 fuel.
Thanks in advance for any helpful comments.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
flybynite
Tue Sep 28, 2021 1:43 pm
If your fuel hoses are original REPLACE THEM no matter what fuel you are using.
steve_k
Tue Sep 28, 2021 5:52 pm
each time i see a post on here or the FB page about E10 fuel & fuel lines it makes me thankfull i changed all my lines to teflon/ptfe lined (E10/ethanol safe) braided steel.
NigelA
Tue Sep 28, 2021 7:00 pm
Many thanks, flybynite and steve_k.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
Tue Sep 28, 2021 7:04 pm
I just dont buy E10 for both the cars, the E46 325 is soooooo much better on economy and performance despite the extra cost.
NigelA
Tue Sep 28, 2021 7:27 pm
(1) Looking in Bentley's it's not clear which are all the flexible hoses (sorry, bad English) - for example there may be one from the fuel tank - and (2) I presume you buy by length and cut to size.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
flybynite
Wed Sep 29, 2021 9:22 am
Yes get a length of fuel injection hose cut to length. Rear pipes better on a ramp but they do not get the heat and exposure and less hot bits to spray fuel over. Still change them but the engine bay is the priority
Good write up is here
https://classicbimmerbits.com/e30-how-t ... placement/
This YT vid shows some things too.
NigelA
Wed Sep 29, 2021 9:26 am
Many thanks, flybynite. Much appreciated.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
jmec
Sun Oct 03, 2021 9:19 pm
There's an article in Pratical Classics addressing the E10 issues.
damers2000
Mon Oct 04, 2021 7:28 am
Thinking that it wouldn't be an issue after reading various posts, articles etc, I put E10 in my 318i and it starting missing after circa 10 miles then just died. As I couldn't find any issues, I drained the tank, fitted a new fuel filter and put 10 litres of shell vpower unleaded in. Car is almost back to how it used to be but just needs a long run to clear everything out. I won't be putting anything in either of my cars now other than Shell vpower.
Mon Oct 04, 2021 5:28 pm
The lad who looks after all the cars told me not to use anything else but this and that was nearly two years ago.
The local Shell garage is on a very busy main road and doesnt always have it for some reason but it always gives better performance and economy (e46 325) than E10.
NigelA
Wed Dec 08, 2021 7:41 pm
Many thanks, martuto. Much appreciated.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
Wed Dec 08, 2021 9:25 pm
All my customers are telling me they are getting reduced milage from the E10 and most are now only using super unleaded
Thu Dec 09, 2021 5:03 pm
:clap: :clap: :clap: :clap:
And I thought is was just me !!....................... NOT. :banana: :banana:
I believe it to be an inferior product to appease someone/thing but is not up to scratch !!
Sainsburys have 50% of their pumps selling E5 97 octane , I have not seen anymore supermarkets doing this............................................................do they know something we dont ????
They have upgraded a lot of their stations recently so a big investment for what could be called "old hat" ??
Keep this going please??
steve_k
Thu Dec 09, 2021 5:59 pm
i guess i'm lucky as i normally only have just half a tank of E10 in the car & only use it a bit as the daily runs 90% of the time on LPG instead,
but, the sport uses V-power most of the time.
Thu Dec 09, 2021 8:36 pm
I buy super either from Sainsbury or Tesco, its the same price as shells E10 rubbish! I cant say if its better or worse as my daily car runs on LPG and averages about 15mpg, I just want decent stuff in the tank as its sits in there a long time
Blanca
Fri Dec 10, 2021 1:28 pm
Recent bit on Goggle about E10 says it is not only very bad for the car, new or classic but produces as much if not more pollutants and as you burn more for the same performance, possibly much more. . I cannot see what possible advantage E5 or E10 is apart from the tax point of view.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
