MOT fail
Ozbear
Post Sat Sep 04, 2021 2:26 pm
So I took my car to mot the other day.. and everything was fine until he went to adjust the headlights with the knob to the right of the steering wheel. It didn’t work and apparently it’s a fail. But I got the car home and decided to have a look to see why it wasn’t working. I understand it’s a vacuum system with coolant in that pushes a rod back and forth adjusting the tilt of the headlights. However the actual system has been removed and there isn’t any mechanical rods that adjust the headlights. How on earth do I go about getting it through its retest if the system isn’t there? He said if the car is fitted with adjustable headlights then they have to work but technically it isn’t fitted with them just the knob is there.
Can anyone help.
Oscar
Blanca
Post Sat Sep 04, 2021 2:34 pm
I don't have one (1987) I would change the knob panel to none adjustable. And try a different MoT station.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
onthames
Post Sat Sep 04, 2021 2:48 pm
Remove the knob and go to a different mot place.
flybynite
Yes if it there it has to work, How much of it has to be 'there' is up for discussion but if you remove the control and the headlights are adjusted properly manually then it should not be a problem. If you don't want to replace the under column cover, just blank the hole off and say it a cover from another car that had it.
They are sealed and impossible to repair but they are available new but seem to be a bit short for original RHD routing.
Post Sat Sep 04, 2021 2:50 pm
I think if you remove the adjusting knob then it wont have a system in place and to be honest , they were never any good in the first place.
You would struggle massively to find one in working order that was for sale.
Have you thought about asking the MOT station about what they would do if you removed the knob ?
I replaced mine with a manual choke , another good point for having a weber lol.
Ozbear
Post Sat Sep 04, 2021 3:03 pm
onthames wrote: ↑
But won’t it be on record online that it has failed for it?
ah
Post Sat Sep 04, 2021 3:10 pm
I must have been lucky then, as mine passed it’s MOT a week ago and mine doesn’t work either.
Post Sat Sep 04, 2021 3:11 pm
Ozbear wrote: ↑
onthames wrote: ↑
Yes but if it`s not there in the re-test then they cant test it?
My take on it but why not ask them ?
Cloggy Saint
Post Sat Sep 04, 2021 3:27 pm
I've been in the same boat. Just remove the knob and take it back for a re-test, it'll pass.
onthames
Post Sat Sep 04, 2021 3:39 pm
Ozbear wrote: ↑
onthames wrote: ↑
You could put a sticky label on the knob that says something like "Sport mode" 🤣🤣🤣
Then you have changed its purpose.
Post Sat Sep 04, 2021 4:06 pm
onthames wrote: ↑
Ozbear wrote: ↑
onthames wrote: ↑
Joking on one side, would that actually work ?
Cloggy Saint
Post Sat Sep 04, 2021 4:09 pm
martauto wrote: ↑
Joking aside, would that actually work ?
Highly unlikely.
Post Sat Sep 04, 2021 4:10 pm
Ozbear wrote: ↑
Oscar
All they have looked at is the knob inside so thats all they should look at for the re- test too.
Quote him on that mate :banana: :banana:
Post Sat Sep 04, 2021 4:13 pm
Cloggy Saint wrote: ↑
martauto wrote: ↑
Highly unlikely.
Is this down to the testers interpretation ??
Just very curious.
Cloggy Saint
Post Sat Sep 04, 2021 5:07 pm
I think it's more down to whether the tester has a functioning brain or not.
Ozbear
Post Sat Sep 04, 2021 5:09 pm
He said if I didn’t have the knob there he wouldn’t have tested it.
But then he failed it on it and said to “get if fixed” and come back. Not remove and come back.
I think I’ll ring him and say it was never actually fitted and take the knob off and take it back but depends if he is feeling funny or not
onthames
Post Sat Sep 04, 2021 5:31 pm
Ozbear wrote: ↑
Personally I'd go somewhere else. If they bring it up you need tell them that the car had its dash replaced and that the new dash came with that knob but you don't actually have the system in the car.
Post Sat Sep 04, 2021 5:52 pm
Ozbear wrote: ↑
I would not use them ever again !!
This is sooooooo petty :evil: “get if fixed” is an answer from some one who has had no "training" in his trade and can NOT use his own mind !!
This type of thing really gets up my back :evil: :evil:
Sorry but this hurts me being a toolmaker and the years you have to do before you are taken serious !!!
Bin the idiot please .
Sorry but "Skilled they are not !! " :up:
Cloggy Saint
Post Sat Sep 04, 2021 6:05 pm
martauto wrote: ↑
Sorry but this hurts me being a tool and the years you have to do before you are taken serious !!!
What are you on about?! Don't blame the tester, he has guidelines to follow and one of those is that if a headlight leveling system is present then it has to work. Would it also be petty if a tyre's tread was 1mm below legal limit and it failed on that?
Ozbear
Post Sat Sep 04, 2021 8:14 pm
so this works then?
twenty
Post Sat Sep 04, 2021 9:39 pm
I’m glad that I bought a knee panel without the adjuster switch cutout and tucked the switch underneath the panel. Heck I’m planning to rip out the tubes etc. out too cause it never worked in the first place anyway.
Cloggy Saint
Post Sat Sep 04, 2021 11:10 pm
Ozbear wrote: ↑
so this works then?
Yes, at least it did for me. If there's no knob then there's nothing to test.
paultv
Post Mon Sep 06, 2021 9:09 pm
I stripped mine out and replaced the panel so there's nowt there.
Paul :-)
fixedwheelnut
Post Mon Sep 06, 2021 10:46 pm
Looks like it has changed, it used to be an advisory so long as the headlamp aim was OK but is listed as a major fail now.
https://www.gov.uk/guidance/mot-inspect ... tion-4-1-1
Remove the knob and go back
Blanca
Post Tue Sep 07, 2021 1:50 pm
Depends on the tester mostly, The rules are a bit of a grey area with lights at times. For instance, If you have a pair of fog lights fitted they must work but if you have fog light switches but no lights do you have to fit the lights, I don't think so as many cars have switches or functions that are not connected on the basic models.
billyfrost
Post Mon Sep 13, 2021 6:34 pm
fixedwheelnut wrote: ↑
Personal views aside, the bottom line is if it's on the car the MOT tester will test it.
billyfrost
Post Mon Sep 13, 2021 6:37 pm
Should add, I've had this on several previous cars, my favourite workaround was to just manually adjust them (get them free first) and then use a different under dash panel from an earlier, non-headlight adjuster version, as per Paul above.
rix313
Post Sun Sep 19, 2021 3:48 pm
This is why I always take my cars to a ‘classic friendly’ station rather than any old jobsworth run of the mill place for your grand fiesta.
I do remember not long ago someone was making a kit which replaced all the components and made it all function again.
jmec
Post Wed Sep 22, 2021 8:48 pm
I asked my MOT tester, many years ago admittedly, about the system and it not working prior to the MOT. He wasn't bothered saying that as long as the headlights could be adjusted, which they can from the front of the lights, he was happy. He used to have an e30 so was well aware of the problem.
