flybynite wrote: ↑Tue Aug 31, 2021 6:40 pm
twenty wrote: ↑Tue Aug 31, 2021 2:38 pm
Looking at the ETK, it seems that E46 interior mirrors should be a straight fit into an E30. I like the design of the E46 mirror as it's slimmer and also the possibility of retrofitting auto-dimming is enticing.
They are also plentiful and cheap so maybe I should take the £8 hit and get one from eBay for the team
Thanks.
Looking at mine, the E46 mirror is attached to a largish box that is glued to the windscreen, you could glue it to an e30 windscreen I guess. The auto dimming mirror has power to it that runs into the box.
I can't see the mirror itself fitting on the 'ball' of an E30 arm because of the wire that needs to run to it unless you use and e30 maplight arm
The trick is to use the whole mirror with arm from E46 or similar cars (see my latest post above) to the E30 screen's base.
The main challenge here is given the number of different mirrors that are compatible, finding the one that is closest to the E30's arm length and angle.
Having said that, I just realized that there's a slight gap in my plan - namely, all the mirror's I've come across so far are self dimming - which means if I don't do the self dimming wiring from the start, there's no way for me to manually dim the mirror (unless I'm missing something).
