Genuine fire extinguisher bracket
onthames
anyone selling genuine fire extinguisher bracket?
steve_k
sam, if you cant find a genuine bracket there's always one of these.
https://www.ebay.co.uk/itm/402314824585
for that price i'll be looking at getting one myself in the next few weeks.
onthames
Seen these, look decent but that goes on the floor right? where as the genuine ones go on the chair afaiksteve_k wrote: ↑Thu Jul 29, 2021 6:26 pmsam, if you cant find a genuine bracket there's always one of these.
steve_k
true but for the price you cant go far wrong, but if a genuine one turns up at the right price then jump on it.onthames wrote: ↑Thu Jul 29, 2021 7:03 pmSeen these, look decent but that goes on the floor right? where as the genuine ones go on the chair afaiksteve_k wrote: ↑Thu Jul 29, 2021 6:26 pmsam, if you cant find a genuine bracket there's always one of these.
also they appear to bolt to the seat mounts/rails for ease of reach.
twenty
Any recommendation for a boot mounted bracket? Personally I prefer one in the boot with a modern extinguisher.
steve_k
i'll be honest i've neever seen one, though i'm sure someone would be able to make one up.
flybynite
Most 2kg extinguishers have a mounting bracket with them, you might need to make something up to put it in a better position
Depends what you want it for, problem is an extinguisher in the boot is as much use as a chocolate fireguard in the event you get trapped in the car. I do put them in the boot but only when I have another in the car
All mine have an original extinguisher under the drivers seat, but that is just for show and for that original flash of red under the seat when you open the door. Would not even try to use them. One of them will likely be replaced with a modern equivalent which look similar.
Each car I have has a 50 second firestick in the glovebox, used two in anger and they are good. You can throw it in the car or boot, or shove it under the bonnet and most importantly you can leave it to work and get clear.
twenty
For a 30 year old car I’m more worried about electrical fires as opposed to getting stuck in a convertible. Good shout about the fire stick - didn’t know it’s a thing. Definitely worth keeping in the glovebox.flybynite wrote: ↑Fri Jul 30, 2021 10:46 amMost 2kg extinguishers have a mounting bracket with them, you might need to make something up to put it in a better position
"Fire stick" ????????????????
Help out an ex fireman please.
twenty
Satan
I have some stock to sell, sold some to the Lotus fraternity and have some left over, they are 50s potassium aerosol type extinguisher. I have one in the kitchen, and in the cars.
http://www.urgentfirepak.com/mangia-fuoco.php
twenty
Are these the same as https://firesafetystick.com/?Satan wrote: ↑Fri Aug 06, 2021 6:10 pmI have some stock to sell, sold some to the Lotus fraternity and have some left over, they are 50s potassium aerosol type extinguisher. I have one in the kitchen, and in the cars.
If so how much is it including post+package?
