Hi, could someone price me complete package for everything to convert auto to manual
325i Manual Conversion
Acaciastrain360
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
Vez010
Hi, I've recently had the same done by BMR Performance. Here's a list of the main parts you'll need to source or buy new.
Second Hand Parts:
- Getrag 26) Manual Gearbox
- 325i Manual Propshaft
- Flywheel
- Manual Pedal Box
Purchased New:
- Propshaft Coupling: 26 11 1 225 624
- Flywheel Spacer: 11 22 1 262 827
- Flywheel Bolts x 8: 1 22 7 805 885
- Clutch Assembly Kit: Sachs kit from: buycarparts.co.uk
- Clutch Master Kit: Sachs kit from: buycarparts.co.uk
- Clutch Slave Kit: Saches kit from: buycarparts.co.uk
- Clutch Fluid Reservoir: 21 52 1 117 729
- Clutch Fluid Reservoir Holder: 21 52 1 154 127
- Clutch Intake Hose: 21 52 1 163 714
- Gear Knob: 25 11 2 231 550
- Gear Gaitor: 25 11 1 221 306
- Gear Shift Rod Joint: 25 11 7 503 525
- Gear Shift Lever Rubber Boot: 25 11 1 220 912
- Straight Selector Rod: 25 11 1 221 657
- Bearing Shifting Arm: 25 11 1 220 707
That's most of the parts from my GB conversion - hopefully that list helps you. Let me know if you have any questions and best of luck with it.
Second Hand Parts:
- Flywheel
- Manual Pedal Box
Purchased New:
Acaciastrain360
Thanks mate that’s a great help!!
Only on the Zone
Acaciastrain360
vonmarshall
That is an awesome list. May I ask what ballpark the total bill was including BMR's time. I cannot find a manual version of the car I want and have been mulling this over as a way forward.Vez010 wrote: ↑Thu Jun 24, 2021 11:10 amHi, I've recently had the same done by BMR Performance. Here's a list of the main parts you'll need to source or buy new.
Second Hand Parts:
- Flywheel
- Manual Pedal Box
Purchased New:
Vez010
I know what you mean in regards to finding the car you want. I’ll put a breakdown together and ping you the details.
(I had various bits done by BMR at the same time so need to work out what’s what.)
Acaciastrain360
Saving the day homie
Vez010
Hi, apologies for the delay - total cost including labour was £2508.39.... breakdown as attached. I chose to have the flywheel lightened and also opted for a short shift lever.
Acaciastrain360
Sweet thanks for that m man!!
Just curious what friggin gear knob you got man haha
