Coolant light query
JimmyMc
Post Wed Jun 16, 2021 8:28 pm
Hello
I have a 1990 320i M20.
Have recently flushed the system as the coolant sensor needed changing.
Bled the system best I could. Now, when I bring the car to a stop, after driving for 15-20 mins, with the engine still running, the coolant light comes on.
Next day, if untouched, the light will be off.
I think air is trapped, and when heated, compresses and lowers the level. Plenty in the tank before, and after.
If it’s air, how do I get it out. Nothing else is coming out of the nipple.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
Bonymaenjack
Post Wed Jun 16, 2021 9:27 pm
JimmyMc wrote: ↑
Hello
Take a look at this
https://www.e30zone.net/e30wiki/index.p ... g#Bleeding
JimmyMc
Post Wed Jun 16, 2021 9:37 pm
I’ve tried bleeding the system with the nose raised. Filled the rad before connecting the top hose.
Air blows hot and was turned on throughout. Temp sits at mid point or just below. Doesn’t overheat. Rad is new.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
fixedwheelnut
Post Wed Jun 16, 2021 10:17 pm
JimmyMc wrote: ↑
Rather than using the small bleed screw undo one of the temp switch blanking plugs as in the photo above, fill up cold until water runs out there, then fill up header tank, refit blanking plug, run engine with heater on hot at approx 300rpm until the coolant can be see circulating in the header tank, top up more if required, fit the cap and run it until hot, then re check the level when cold again, next day usually.
JimmyMc
Post Thu Jun 17, 2021 8:16 am
Thanks. So should I drain and start again?
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
mark_i
Post Sat Jun 19, 2021 7:08 am
Hey Jimmy. draining not necessary.
2 things i would check:
i/ the thin tube from the top of radiator to expansion tank is clear
ii/ maybe a level sensor wiring issue . ..
JimmyMc
Post Sat Jun 19, 2021 7:36 pm
mark_i wrote: ↑
Thanks. I’ll investigate those. I think the top small rad hose is okay though.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
