so a few minor updates, maybe due to the warm weather, the engine would start and would keep going when throttle is given.
There is constant white smoke when this is done.
when the accelerator is let go, it will either die or idle very badly (for less than a minute) until it dies.
We have removed the cylinder head and timing covers (Both crank and cam were at TDC)
we plan to replace the belts and gaskets just in case coolant is getting in the head. (THere is no milk gunk anywhere, just white smoke)
the valves on the camshaft are in the following position @ TDC, is that normal (See image)
