M40 318i fuel pump
SAP1
Post Sat Mar 27, 2021 12:47 pm
Apologies if this has been covered before!
My fuel pump on the 318i M40 has finally packed up.
Anyone know which replacement I need for this? Don’t really think I need the whole unit just the pump itself?
Is there a like for like replacement for the pump?
Thank you!!
rix313
Post Sun Mar 28, 2021 3:16 pm
SAP1
Post Tue Mar 30, 2021 7:16 pm
Cheers mate thanks!
In the end went for one of these instead.
https://www.ebay.co.uk/itm/For-BMW-3-E3 ... 890.l49286
brutus
Post Wed Mar 31, 2021 1:43 am
,,, ohhhh,,
i see that as a m10 fuel pump.
,,,please tell im wrong ?
regards,
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
Post Wed Mar 31, 2021 5:12 pm
brutus wrote: ↑
,,, ohhhh,,
regards,
I think the M10 is a mechanical pump.
Post Wed Mar 31, 2021 8:24 pm
martauto wrote: ↑
brutus wrote: ↑
,,, ohhhh,,
regards,
M10 carb. uses a mechanical pump. M10 injection uses an electric pressure pump, the same as any other 'i' E30.
Early cars used an external (to the tank) pressure pump fitted in front of the rear left wheel, sometimes with an in tank low pressure electric lift pump, and later cars use a high pressure pump inside the tank.
The redundant external pump position was used for the fuel filter on 6 pot cars, but not on 4 pots.
