Fuel hoses
yaad
Post Fri Mar 05, 2021 12:47 am
Hi guys
I am changing the two fuel pipes that come into the engine from below the car. Doesnt anybody the diameter or size of these pipes? Its the pipes bringing the fuel to the engine. And the approx lengths of these?
Am i better off buying new from a shop or from a breaker?
Yaad
biffer
Post Fri Mar 05, 2021 1:26 am
Sizes are 8mm internal diameter/13mm outer diam., and i found 2m was enough to do my car which has fuel-pump just in front of rear wheel.
I avoided Ebay stuff and got Gates hose from local factor for about £4 per metre.
Halfords sell this hose for about £7 per. m.
Or BMW sell it for gawd-knows-how-much.
yaad
Post Fri Mar 05, 2021 7:59 am
Perfect, halfords have one with internal diameter 8mm but external , would 2mm external make a difference
twenty
Post Fri Mar 05, 2021 9:26 am
Someone mentioned these are perfect fit. And E10 compatible. https://www.ebay.co.uk/itm/382558398973
As for me, they were all redone using genuine hoses from BMW. Probably more expensive but it’s a safety critical part so I didn’t want to gamble.
Post Fri Mar 05, 2021 9:36 am
BMW supplied hose is much better quality than anything you will find in a motor factors and will undoubtedly last longer too
Post Fri Mar 05, 2021 2:11 pm
yaad wrote: ↑
or from a breaker?
You are contemplating fitting second hand rubber hose????
Bonymaenjack
Post Fri Mar 05, 2021 3:05 pm
Brianmoooore wrote: ↑
yaad wrote: ↑
or from a breaker?
:eek:
Post Fri Mar 05, 2021 3:10 pm
I think (hope) he was asking for advice winkeye
twenty
Post Fri Mar 05, 2021 4:37 pm
DanThe wrote: ↑
Do you know if the BMW hoses are E10 compatible? I didn't check when I fitted mine but I do hope that the spec has been upgraded from the original design from 30 years ago :)
yaad
Post Wed Mar 10, 2021 10:28 pm
Thanks for the advice guys! I ordered some from BMW after your recommendations
Should last many years now
Thanks 😊
