Scorpion Down pipe and e46 rack conversion
satvir
Anybody have any experience of doing the e46 purple tag rack swap, with a scorpion exhaust system. Factory manifold, Scorpion down pipe, middle section and back box.? Any clearance issues? Fitment issues? For a 325i
The standard 325i downpipe gives clearance problems, so if the scorpion is slightly larger it will give problems also
twenty
Did you ever get around to doing it? One option I had considered was to simply use taller engine mounts.
