M20 b25 slight misfire
Gaffasgaff
Post Sun Feb 14, 2021 6:20 pm
Hello guys . So I have noticed when holding the revs around 2500 rpm I'm feeling a slight misfire while my hand is on the inlet manifold .
Whilst I was on furlough I have done a fair bit of work to the engine .
I replaced the head gasket. Had the head tested skimmed and rebuilt . Full service oil , oil filter , air filter , fuel filter , new spark plugs ( gap checked ) Genuine HT leads and cambelt .
Fuel pressure tested all came back ok .
Compression tested all 6 cylinders came back above 150psi .
Afm bench tested by first testing the temp sensor pins 4 and 1 all came back good operating correctly. I put a 9v battery to pin 4 and 3 and tested the voltage at pin4 and 2 and voltage increased smoothly when opening the door to the afm . No problems there . I'm very certain there is no vacuum leaks at all .
Really confused . I have replaced the coolant temp sensor a while ago now so that's been done . . This was doing this before I done all the work to the engine .
Need some expert advice please :cry:
ah
Post Sun Feb 14, 2021 7:40 pm
You would be better
Putting this in E30 technical help
Gaffasgaff
Post Sun Feb 14, 2021 9:02 pm
ah wrote: ↑
You would be better
Ok thank you . Trying to figure out how to delete this post and upload it on the technical page
BenHar
Post Sun Feb 14, 2021 10:12 pm
How long since the injectors were serviced?
Ben
Gaffasgaff
Post Sun Feb 14, 2021 10:32 pm
BenHar wrote: ↑
Ben
Hi Ben. I have never had them serviced . But I remember around 5 years ago I had them out changed the rubber o seals and made this tube to go over the injectors so that I could spray carb cleaner through the injectors to clean out any gunk . . I have recently had my stethoscope on each injector while the car has been running and they all pulse the same when car is running .
BenHar
Post Sun Feb 14, 2021 10:38 pm
It may not be the cause, but they are would definitely benefit from a full refurb.
Ben
Post Mon Feb 15, 2021 12:07 am
Topic moved.
Are you sure there's a problem? The straight six is an inherently balanced and smooth engine, but it's still an ICE with three bangs per rev., so won't be as smooth as an electric motor.
Gaffasgaff
Post Mon Feb 15, 2021 5:42 am
Brianmoooore wrote: ↑
Topic moved.
Topic moved.
Hi Brian. Well it just seems strange . Its not smooth at all while holding the revs . Definatly feels like something ain't right . I will try and take a video of it when I get chance and upload it . Idles totally fine . Only happens when revs are held around the 2500 rpm. Really could do with a comparison with another m20
paultv
Post Mon Feb 15, 2021 7:04 am
Do you feel any missing or lumpy response under load..ie whilst accelerating away in 2nd...can you feel hesitation or anything as you pass through the power band?
Paul :-)
Gaffasgaff
Post Mon Feb 15, 2021 8:45 am
paultv wrote: ↑
Hi Paul .Last Time I drove it was in June last year . I didn't feel any hesitation or lumpy response.
Paul :-)
fixedwheelnut
Post Mon Feb 15, 2021 3:40 pm
Gaffasgaff wrote: ↑
paultv wrote: ↑
Paul :-)
If it hasn't been run since June there is a good chance carbon has built up from consecutive start ups and idling, you might be feeling the carbon burning off, I wouldn't worry too much until you have driven it on the road and see how it performs, the other cause of lumpy running could be an air leak so if you have access to a smoke tester that will save you hours of guess work.
Tineca
Post Mon Feb 15, 2021 4:46 pm
Pop the old plugs and leads back in just to eliminate. If it wasn't there before then something isn't right. Is it timed up perfectly?
Gaffasgaff
Post Mon Feb 15, 2021 8:21 pm
Tineca wrote: ↑
Hi . It was doing the same with the old leads .
100 percent timed correctly . :cry:
Gaffasgaff
Post Mon Feb 15, 2021 8:25 pm
fixedwheelnut wrote: ↑
Gaffasgaff wrote: ↑
paultv wrote: ↑
Paul :-)
Hi mate hows it going . I will do a smoke test on the intake system . I have sprayed carb cleaners around the intake hoses ect and there is no change in engine note . I might get the injectors tested professionally and see how I get on . But first I will smoke test :D
