Hi all,
I have a 325i E reg car and the batteries have leaked all over the SI board. It doesn’t look very happy. Just need a good working board or if need be the whole cluster?
Tah
325i cluster board
rix313
fixedwheelnut
Is it salvageable? I modify mine using a AA x 2 battery holder and mount some rechargeable batteries on the outside of the cluster with velcro.
https://www.amazon.co.uk/AA-Battery-Hol ... 5130&psc=1
The board is lacquered, but if the crud has got under it, into the thin tracks around the battery area, then it'll be a major, time consuming job, for someone with much better eyesight than mine, to repair it.
Never understood why anyone would want to fit an external battery tray. There's no worthwhile advantage.
fixedwheelnut
I did it on one of my earlier ones so I could disconnect them when I left the battery off for a long time and also if the batteries do leak they wouldn't damage the board, plus the added bonus of about five minutes to change them if I needed toBrianmoooore wrote: ↑Sat Jan 02, 2021 8:06 pmThe board is lacquered, but if the crud has got under it, into the thin tracks around the battery area, then it'll be a major, time consuming job, for someone with much better eyesight than mine, to repair it.
rix313
Sadly Brian it looks like someone has A: had a go in the past at replacing them and B: the replacements have caused what looks like layers of the lacquer to lift. It’s a bit of a mess.
rix313
Still require one of these. Can be a complete cluster not a problem.
Hi Rich , You all OK ? mate ??
Have you tried Mick (Magpie) or Pete (sweep) ??
Robbo-80
PM Sent
