Hi all, please forgive me if this is a really naive question, I’m still learning!
The rad on my 325i was corroded so I’ve brought a replacement, a Nissens one as could afford the £450 bill from beemer.
It arrived as I assumed damaged but the supplier are saying the below ‘cuts’ on the top and bottom of the rad are intentional to stop bowing... anyone know if that is that BS or reality?
E30 Cab Radiator Question
bexwoods
Dolphin Grey 325i Cabriolet
Check out my restoration thread!
viewtopic.php?f=112&t=279183&p=2964331#p2964331
HenryM3
I have not seen this before just been out and looked at the new VW rad I’ve fitted an there’s no cuts, none on the m3 radiator either. Not saying it’s wrong as there my be some new technology/thinking behind the cuts. Maybe look up your rad on eBay/Amazon and see if there is any visible cuts like that. Perhaps someone who has recently fitted that make will chime in.
bexwoods
Thank you. All the images are the ‘blueprint’ style rather than physical images :/HenryM3 wrote: ↑Mon Jan 11, 2021 2:45 pmI have not seen this before just been out and looked at the new VW rad I’ve fitted an there’s no cuts, none on the m3 radiator either. Not saying it’s wrong as there my be some new technology/thinking behind the cuts. Maybe look up your rad on eBay/Amazon and see if there is any visible cuts like that. Perhaps someone who has recently fitted that make will chime in.
I’ve googled it and it seems to be a thing that is done to help prevent bowing when hot.
HenryM3
If your research has made you feel confident that all is okay then go for it and fit. I’m sure it must come with some sort of warranty so make sure you keep the receipt in a safe place.
It has been done for a reason of which I know nothing about but remember that it costs them to do this so maybe it`s something of a benefit ??
biffer
My Nissens pre-facelift 325 rad that i got recently didn't have this feature, but looking at the pic. that cut looks intentional rather than any sort of damage.
bexwoods
Thanks all... think we’ll give it a go.
