M20 oil breather tube
JimmyMc
Post Mon Dec 21, 2020 11:17 am
Hi all,
Been sorting out a leak on another thread.
Wanted to clear up whether people have used a washer at the top of the tube, as well as the bottom. Realoem lists 2, but there wasn’t one there when I took it off.
Thanks.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
JimmyMc
Post Tue Dec 22, 2020 9:49 am
I’ve seen 2 versions of the story.
1. O-ring at the top, then spring, washer, o-ring on the bottom.
2. O-ring at the top, then washer, spring, washer, o-ring.
What has everyone done that worked?
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
reggid
Post Tue Dec 22, 2020 10:40 am
i wouldnt do washer at the top (even though i thinks how BMW did it) it seems to not allow the o-ring to seat fully
E30 325is with M20B31
JimmyMc
Post Tue Dec 22, 2020 9:38 pm
reggid wrote: ↑
I think that’s what I’ll go with. Thanks.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
reggid
Post Wed Dec 23, 2020 1:59 am
JimmyMc wrote: ↑
reggid wrote: ↑
just do a mockup the tube and o-ring into the manifold to see. these days im running a different manifold so recollection regarding the stock one is shady
make sure you lube the o-ring with oil or suitable grease otherwise it may tear
JimmyMc
Post Wed Dec 23, 2020 2:20 pm
Seems to be another problem. When inserting the tube with the IM attached, the bottom of the tube doesn’t engage with the block when the top is fully engaged.
Does anyone happen to have any tube dimensions? I think it’s been, cut but not sure. I assume this was part of the original bodge.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
reggid
Post Wed Dec 23, 2020 10:48 pm
yeah should be like 48mm. someones lopped off 10mm
twright
Post Thu Dec 24, 2020 1:31 am
I'll bet someone cut 10 mm off of it to try and make it so that you could take that tube off without taking off the intake manifold.
Did shortening it work?
paultv
Post Thu Dec 24, 2020 4:54 am
How important is it that this tube is airtight to the manifold and sump area? Surely it has to be leak free to avoid idle running issues in the same way as the dipstick and oil filler cap/ breather hose.
Correct ?
Paul :-)
reggid
Post Thu Dec 24, 2020 6:01 am
paultv wrote: ↑
Correct ?
Paul :-)
it is a "vacuum leak / unmetered air" if you have the valve cover venting back to throttle body like the factory.
If you plug throttle nipple and vent valve cover to atmosphere it doesnt matter as it is nolonger a vacuum leak/unmetered air
JimmyMc
Post Thu Dec 24, 2020 8:52 am
twright wrote: ↑
Yes, I was ultimately able to get it in and out with the IM on, which was an alarm bell. They’d filled the gap with sealant held in by a ball joint boot! I’ve ordered a new one, as I’m sure this is where my air leak was.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
JimmyMc
Post Thu Dec 24, 2020 8:54 am
reggid wrote: ↑
Thanks for confirming. Useful to the info recorded.
I’ve ordered a new one.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
BristolE30
Post Thu Dec 24, 2020 12:31 pm
I’ve never seen this before on my oil breather tube? Isn’t it just hose clamped on??
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
Cloggy Saint
Post Thu Dec 24, 2020 1:37 pm
Can't use a hose clamp on this as both ends are 'male'.
JimmyMc
Post Tue Dec 29, 2020 3:33 pm
reggid wrote: ↑
I can confirm 48mm from the bottom of the lower lip is correct. New part has arrived.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
HJ1981
Post Sun Jan 03, 2021 7:03 am
As i pulled mine out, i only found one washer, and it was sitting above the O-ring.
Basically spring, washer then O-ring. I did order two of those o-rings and it looked strange and never got the o-ring to seat in properly, so i just used one.
BristolE30
Post Tue Jan 05, 2021 11:39 pm
Cloggy Saint wrote: ↑
Mine is just hose clamped on unless we are talking about different parts. Tube that goes from the valve cover to the intake manifold?
BMW E30 316 ‘87
Bristol, UK
JimmyMc
Post Wed Jan 06, 2021 8:07 am
BristolE30 wrote: ↑
Different part I think. The tube runs from the underside of the intake manifold to the engine block. It’s made of metal with an o-ring either end.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
