Vac leak - eliminated some, what’s left
JimmyMc
Post Sun Dec 13, 2020 12:06 pm
Morning all,
Trying to find a vacuum leak this morning to help with a lumpy tick over.
I’ve rigged up a test, without smoke, and can hear a leak. I’ve narrowed it down to the valve cover onwards (into the engine and not back toward the tb).
It doesn’t sound like it’s coming from the valve gasket or bungs (which are new). Sounds to be low down near the intake manifold bolts. Doesn’t seem to be dipstick related.
What else do I need to be checking?
Thanks in advance. A smoke test would be much easier, but haven’t got the stuff at the moment.
320i auto 1990.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
twright
Post Sun Dec 13, 2020 6:06 pm
If this is an M20, there is an o'ring that is sealing a vent tube to the block from the intake manifold. It's tough to see and you have to take off the intake manifold to replace it.
JimmyMc
Post Sun Dec 13, 2020 6:10 pm
Thanks. Yes, an M20.
Does it often go? And is it just one at the top?
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
JimmyMc
Post Sun Dec 13, 2020 6:22 pm
Had a look on realoem and spotted a seal at the bottom but not the top. So could it be the bottom seal? It looks a bit oily down there around the spring.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
Post Sun Dec 13, 2020 7:30 pm
The ETK diagrams are in no way an assembly guide. There's a flat washer (11) and an O ring (10) at each end of the tube, but only one spring.
They're not a common problem, but, like anything rubber, they harden with age and heat, and usually need replacing if disturbed.
JimmyMc
Post Sun Dec 13, 2020 8:03 pm
Thanks Brian. I’ll order a couple of seals. Can it be done without removing the IM?
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
Post Sun Dec 13, 2020 8:12 pm
Top one can be, but not the bottom.
Grease the O rings well, and tie the spring in a compressed state with a couple of small cable ties or thin wire. Once the inlet manifold is back on, cut the ties, and make sure the top O ring goes fully into place.
paultv
Post Mon Dec 14, 2020 8:43 am
Matter of interest, did you check the little rubber bung attached to the underside if the TB? They have a habit of perishing and falling off.
Paul :-)
JimmyMc
Post Mon Dec 14, 2020 8:48 am
Paul :-)
Hi. It still seems to be there, and don’t think it was where the leak was coming from.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
JimmyMc
Post Mon Dec 14, 2020 8:51 am
In order to get a complete kit of parts, if I order 2 o-rings and the gaskets, should I replace anything else while I’m there or leave alone?
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
Post Mon Dec 14, 2020 10:49 am
Nothing to replace as such, but a few things to check. You can open up the rubber boots of the plug and socket for the injectors, under the inlet manifold, and check for corrosion, you can check the rubber cap underneath the throttle body, mentioned above, and you can check the alloy elbows on the side of the throttle body are all firmly seated.
The inlet manifold gaskets themselves are a common source of air leaks. They become brittle, and a section of the gasket breaks away and gets sucked into the engine, leaving a small slotted hole. It often gives itself away by making a whistling noise under high vacuum conditions, but not always.
JimmyMc
Post Sat Dec 19, 2020 5:24 pm
So, stripped it down today and found this.
Looks like no o-ring and no washer at the bottom.
Covered in mastic. And a rubber boot at the bottom.
Do I need to replace the rubber boot at the bottom? Not seen that before.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
Post Sat Dec 19, 2020 6:56 pm
No rubber boot there on any M20 I've ever seen. I think your car has been the victim of a first class bodger!
JimmyMc
Post Sat Dec 19, 2020 7:04 pm
My thinking exactly. Looks like it might be a ball joint boot.
Looks like I just need to get a washer.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
JimmyMc
Post Sun Dec 20, 2020 9:03 pm
Do I need a washer at the top and the bottom?
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
JimmyMc
Post Tue Dec 22, 2020 4:07 pm
Paul :-)
Having got the IM off, with the TB still attached, I had a look for the bung, and there doesn’t appear to be one. Just the body of the socket which is one piece plastic. Will be putting it all back on tomorrow.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
Post Tue Dec 22, 2020 8:09 pm
Spigot wouldn't be visible in that pic. It's tucked in below the TPS, and very close to it.
