Heater blower only working in position 4
Bally325
Post Fri Nov 27, 2020 3:54 pm
Hi bmw e30 325 auto suddenly heater blower only works on the fastest speed never been noisy or anything just stopped working at slower speed and ideas what the check is it easy to replace the heater motor and from engine bay or from inside thanks
Bonymaenjack
Post Fri Nov 27, 2020 4:15 pm
Not a difficult to do , access to it is through the engine bay . Sounds like maybe a resistor has failed ?
https://www.e30zone.net/e30wiki/index.p ... nly_on_Max
Dlb26
Post Fri Nov 27, 2020 5:33 pm
Try a good clean first, worked for me. Mine did the same after last winter hibernation
964russ
Post Fri Nov 27, 2020 7:16 pm
Mine just needed a spray.
Removed cover from engine bay, loads of spray oil, spun it by hand.
Sorted
Post Fri Nov 27, 2020 7:19 pm
If the fan spins freely, as it might, from what you say, then the problem is either with the rotary switch or the resistor pack, and it's unlikely to be the switch.
There is a bimetallic thermal cut out built into the resistor pack, and if you're lucky, cleaning the contacts of this may effect a cure.
Unfortunately, heat from the contacts making a poor connection before it totally fails, often melts the plastic, writing the pack off.
Post Fri Nov 27, 2020 7:22 pm
Sorted
Freeing it up with WD40 or similar, and then calling it a day, as suggested in the wiki, will be a short lived cure. The bearings of the motor are porous bronze, and need a good dosing of light oil if they are to remain healthy.
964russ
Post Sat Nov 28, 2020 6:12 pm
Been ok for sum time now.
Only time will tell
