Sorted one fault but not the long term one.
ah
Post Tue Nov 24, 2020 7:31 pm
The fault I’ve sorted is that it was running on 5 badly for half an hour and then run on 5 and half for the rest of the time, anyway tracked it down to no.5 plug lead corroded.Anyway for those who don’t know about my 10 year old fault, driving down a road at 40/50/60 and roll off the throttle down to 1500/2000 rpm and the car kangaroos, also if the engine is reved up the revs drop and it nearly stalls but it never has.Over the years I’ve changed a lot of things but with no luck.
Bonymaenjack
Post Tue Nov 24, 2020 8:00 pm
I have virtually the same problem, I ease off the throttle and the car sort of wants to stall but doesn't and the engine seems to run unevenly, foot down and she's fine with no hesitation.
ah
Post Tue Nov 24, 2020 8:29 pm
Couple of questions, is yours a 320i, and does yours happen around the same revs.
Bonymaenjack
Post Wed Nov 25, 2020 9:29 am
no she's a 2.5 but normally when I come off the pedal at around 30mph when she sounds/feels like a misfire, , fitted new everything on the ignition side which is no guarantee I know
ah
Post Wed Nov 25, 2020 8:11 pm
So we both talking m20 engines, we have properly both changed the same amount of things, anyway if I every sort mine I’ll let you know.
twright
Post Thu Nov 26, 2020 12:02 am
My M40 powered car did that until I raised the idle (tickover?) speed a little.
Can you change the idle speed on an M20?
ah
Post Thu Nov 26, 2020 6:30 pm
I know where your coming from but my car is not idling slow, cheers anyway.
